Old 06-12-2022, 10:12 PM
67_Bird 67_Bird is offline
Default Inner fender wells
How do they come out? Does the entire fender have to come off? Can’t get the passenger side out all bolts are out including the big one at the lower rear fender.
Old 06-13-2022, 01:07 PM
grivera's Avatar
grivera grivera is online now
I ended up removing the outer and inner for a Vintage Air install cause it seemed easier. That being said, the procedure calls for removal of the two bottom, outer fender bolts near door at rocker panel and then pulling on the lower fender to make clearance for the inner fender to come out. FWIW, I didn't try it this way so not sure if it works.
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
