Old 07-02-2022, 03:05 PM
77 TRASHCAN's Avatar
Woe, I don't think even Wayne Carini would desire that "stuff" on a barn find.........
Shut it off
Shut it off
Old 07-17-2022, 05:50 PM
SD455DJ SD455DJ is offline
Default RAIV Engine Removal & Teardown
It's been a couple of weeks since the car was looked at, so this past weekend lots of work happened. Dan removed the ’69 WH code RAIV engine out of the ’66 GTO and tore it down. He was happy to see that it is really clean inside and not rusty from sitting the past 42 years. The engine was rebuilt sometime in the mid to late 1970’s and has some good-for-the-time .030”-over Forged-True brand pistons with full floating wrist pins. These are the pistons with the Teflon buttons in the skirts. Even more amazing is it still has the original 041 ‘T’ RAIV cam and limited travel factory lifters. Unfortunately, it’s lost a couple of lobes and the bearings show scoring from metal shavings circulating in the oil system. The 722 heads still have their original swirl polished/tuliped valves, not sure if the springs are original as there are 2 different style of retainers, factory and a couple aftermarket. The RAIV pushrods and guideplates are still present, though the #1 intake and #5 exhaust pushrods were slightly bent and the #1 exhaust pushrod guide was broken, but with a shade-tree repair to go along with the shade-tree engine rebuild.
The block, heads, and manifolds are headed out to get cleaned and magnafluxed tomorrow and hoping for a clean bill of health. The frame was torch-cut to clear the driver side RA exhaust manifold and wasn’t reinforced in any way.
Lots of decisions to make in the near future about what direction to take with the engine.
Dennis
ID:	594522   Click image for larger version
ID:	594523   Click image for larger version
ID:	594524   Click image for larger version
ID:	594525   Click image for larger version
Old 07-17-2022, 05:54 PM
Forgot to mention the blocks casting date is A109 and the '68 RAII exhaust manifolds are C138 (or C188) & C218. The manifolds look crack-free to the naked eye, but magnafluxing will tell the real story.
Dennis
ID:	594527   Click image for larger version
ID:	594528   Click image for larger version
Old 07-17-2022, 06:13 PM
25stevem's Avatar
25stevem 25stevem is offline
Thanks for keeping us informed!
Man, I can’t believe that frame was not reinforced after so much was cut out!
I do stuff for reasons.
Old 07-18-2022, 07:18 AM
Yes, it's definitely crude! We are wondering if this engine ever saw much street time and figure he must have bent the pushrods early on and then just parked it in 1980. I'll have to ask Dan if the wiped cam lobes are the same ones as the bent pushrods. It couldn't have run very well with the 4GC carb on the P4B intake along with just a kink bent 2" exhaust system, ST-300 2-speed trans with a 1.76 first gear and a 3.23 rear gear. He must have been too disappointed to fix it and put it back on the streets.
Dennis
Old 07-18-2022, 09:09 AM
25stevem's Avatar
Some lessons are hard learned, but it's a blessing in disguise I would say that the push Rods bent from what was likely valve float yet the connecting rods held in.
If not it would have been another block with a port hole in it!
The Following User Says Thank You to 25stevem For This Useful Post:
Old 07-18-2022, 10:09 AM
johnta1 johnta1 is online now
The VIN, however, is hardly legible and can only make out the last 4 digits clearly, the others just barely visible and not legible.
Get anymore of the VIN exposed on the engine?
Old 07-18-2022, 12:52 PM
John, It looks like 29xxx0765. The plant letter and first 2 digits just don't exist. The '9' for the year just barely shows as does the '0'.
Dennis
Old 07-29-2022, 03:21 PM
25stevem's Avatar
Does this look to have its original timing chain and gears?
Old 07-29-2022, 09:29 PM
Steve25 - No, it had stock replacement steel gears and Morse chain. It was worn/loose, but not terrible.
Dennis
Old 07-30-2022, 06:46 AM
25stevem's Avatar
Thanks much!
I was just curious if it still had the stock set up which I have been wondering if the IV motors with there far higher 320 psi of open pressure would have still been fitted with the Aluminum Nylon cover cam gear or not.
Dennis, do you know anyone who could answer this stocker RA4 question?
Old 07-30-2022, 10:36 AM
Tom Vaught's Avatar
Boost Engineer
The two RA-IV cars I took apart in 1970 at my Uncles dealership both had the Steel Gears, BUT they also had an aftermarket Edelbrock 4 BBL intake on one engine and the other engine obviously was a racer with Hooker Headers. So No help on that one.
They were both RA-IV SD engines.
Tom V.
Old 08-08-2022, 11:47 AM
starlightblack's Avatar
starlightblack starlightblack is offline
Have you approached PHS yet? Have they said it's enough info for an invoice?
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 08-08-2022, 12:23 PM
Tom Vaught's Avatar
Boost Engineer
This wasn't Ralph Pipers 66 GTO that he ran at US-131 for many years, was it?
He raced that car many times there. He was also one of the starters who worked the
starting line back in the 1976 time frame. Ralph lived south west some miles from US-131 location.
Tom V.
Old 08-08-2022, 12:55 PM
Des - No, it's inconclusive...potential VIN's weren't found unfortunately. We tried all the '69 F-bird combinations with JM with Loraine, Norwood and Van Nuys plant codes.
Dennis
Dennis
Crap.
Old 08-08-2022, 12:59 PM
Tom V.
Tom, I remember Ralph. He ran a faded brown/gold 64(?) bracket racer Tempest wagon with Rally II's all around for a while. However, this '66 GTO was never owned by Ralph...good memories otherwise!
Dennis
  #38
Old 08-08-2022, 01:01 PM
Crap.
Agreed! The VIN wasn't found, not that it doesn't/didn't exist. Very few come up inconclusive, and this is one of those very few.
Dennis
  #39
Old 08-08-2022, 01:41 PM
Tom Vaught's Avatar
Boost Engineer
Dennis
Do not remember the 64 Tempest wagon but I left the west side of the state in 1975. When I knew him, he had a early GMC truck (that he pulled his trailer with) and he ran the 1966 A-Body car. He later ran a 71 455 HO car too. No memories of the 64 wagon but that has been many years ago.
Tom V.
  #40
Old 08-08-2022, 02:27 PM
I do recall his wagon being 455 powered (mid-12's IIRC)...from the HO car? I think this was the later 70's when we were running our '65 428 Tempest coupe.
Dennis
