Old 07-08-2022, 03:14 AM
dataway's Avatar
dataway dataway is offline
Default 68 Fender installation
I know this has been covered elsewhere, but I like to ask 68 owners about things that might be specific to a 68, and I know many people here have done this not that long ago.
Is it best to install the fenders with the inner fenders already bolted on the car, or to install the fenders with the inner fender bolted to them? Jeez I have enough problems getting the inner fenders installed without the fenders, would be quite the Rubrics Cube with them already bolted together ... but I suspect that's the way it should be done.
What has your experience been?
Old 07-08-2022, 03:03 PM
Verdoro 68's Avatar
I just did mine with the inner fenders bolted up to the body because I wanted to be careful to minimize scratching things. The inner fender took a little adjusting to get it the bolt holes aligned, but it wasn't that big of a deal if you're careful.
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - 3.55 posi (build thread | walk around)
'95 Comp T/A #6 M6 - bone stock (pics)
Old 07-08-2022, 03:41 PM
69gtocv 69gtocv is offline
^ this.
I loosely bolted the inner fenders to the cowl and core support if I recall correctly. Then I set the fenders up and over the inners.
The Following User Says Thank You to 69gtocv For This Useful Post:
Old 07-08-2022, 03:55 PM
Verdoro 68's Avatar
Yes, everything loose to start. Got the fender aligned, shimmed and bolted down, then circled back and tightened up the inner fenders last.
It’s way less cumbersome to move a fender vs. a fender and an inner fender attached together.
Ken
Old 07-08-2022, 04:05 PM
dataway's Avatar
Excellent, I was hoping it could be done that way .. would have to be a nightmare aligning a fender with the inner bolted to it.
My main worry was getting the inner fender lip ABOVE the fender lip where it belongs as I get the fender hung on. But I guess if it's loose enough you can kind of cock it towards the engine and hook it up there later.
Thread Tools
Display Modes
