Old 08-06-2022, 01:48 PM
RA1John RA1John is offline
Default Fuel Vapor Line Hose Clamp (Wittek-Tower, SG-18)
Has anyone found a source for the assembly line Wittek Tower Clamps
used for Fuel Vapor Return Line Hose?
Stamped "SG-18"
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
The Following User Says Thank You to RA1John For This Useful Post:
Old 01-31-2024, 06:27 PM
68pongto's Avatar
68pongto 68pongto is offline
If anybody is still looking for these tower hose clamps, D&M Corvette in the Chicago area has some for sale. They say they got them from the closed Wittek warehouse. They are advertising them on a Facebook group.
The Following 3 Users Say Thank You to 68pongto For This Useful Post:
Old 01-31-2024, 10:53 PM
400 4spd.'s Avatar
I'm wrapping up a 69 RAIV. Can anyone confirm if the pump on the IV used that clamp?
Old 02-01-2024, 12:28 PM
68pongto's Avatar
The 69 GTO assembly manual shows all V8's using the mini tower hose clamps on the vapor return line at the fuel pump and frame connections. The pinch clamps are used back by the fuel tank.
Old 02-01-2024, 06:19 PM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
Stamped "SG-18"
You might give these folks a try, I saved this link off a long time ago, but I did buy some of these style clamps for my 66.
https://www.martiauto.com/itemselect...lecteditem=yes
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
The Following User Says Thank You to ftwmlp For This Useful Post:
Old 02-01-2024, 07:07 PM
Jason67's Avatar
Jason67 Jason67 is offline
I wonder if these are used on the vapor return line on a 67 HO filter or 66 tri-power filter with vapor return down by frame? My guess is not, since the filter itself uses all pinch clamps.
The 67 assembly manual shows the second design fuel pump with the vapor return using these tower clamps, but I cannot find drawings for the HO filters to verify...
Jason
