The noise from the A-6 might be from low oil level. You can buy NOS oil charge for R12 systems for $15 shipped which will give it 2 oz. of oil and 2 oz. of R12 in each shot.
I have a JPEG of my certification number that I send to the seller if bought online, and I have a cert. card I provide if buying in person. I bought a few pounds at Carlisle last year for $15 a can.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
Great to hear!
R12 is easy to find on Craigslist or from relatives. No license needed. If you get the license, it used to be a $30 open book test. No idea how it is nowadays. If you have no source for R12 you might as well convert to 134a.
http://www.pontiacpower.org/ |
It was $30 a couple of years ago, and it was an open book test. Like most things, it seems to be a money grab. The course is really common sense.
Evacuated the R134a at work, drained the oil out of the VIR, changed the dissectant bag, pulled a vacuum on it, put in some r12 oil charge, then just installed the R12. Blows ice cold at idle again.
BTW, what type of oil is available for our old R12 systems if we keep them R12?
Ester oil is safe for both refrigerants, but will not work as well in R12 systems as the refrigerant mineral oil that is used specifically with R12. Mineral oil is less hygroscopic so it is not inclined to hold water and carry it throughout the system. All oils are easy to obtain currently.
PAG oil is to only be used with R134A.
I had the same exact results. My system is the Late 1976/1977 controlled clutch system. I replaced the receiver/dehydrator, condenser, orifice, evaporator, o-rings, drained and refilled the compressor due to age/contamination 2 years ago. I haven't touched it since and it blows ice cubes out of the vents at all times, and cools down quickly.
The 134a will be more expensive here in the very near future due to an excise tax that will be put on it because the new cars are gradually switching over to R1234y. So then the "retrofits" will have to pay a premium to be able to recharge with an inferior refrigerant.
Yes, it is time to stock up on R134A for the newer daily drivers..
Classic Auto Air (Florida) can rebuild anything you have on the A/C system. It will come back looking slightly better than new and work perfectly... I worked for them for almost 3 years so I can say this with some confidence
