Intake manifold stud location 1970 GTO.
The car I'm restoring was pretty much together except the seller took the intake manifold off to look inside the engine. He put the bolts in a bucket. I pulled out what looks to be five bolts and five studs that fit the ten intake mounting locations. This is an A.C. car. I have seen pics showing studs on the pass. front two holes and the driver side second one back. That accounts for three studs. Can someone enlighten me please.
2001 WS6 convertible, triple black 427 LS7 block with a Vortech YSi, 9.93@143.81 (original owner). 1970 Paladium silver GTO, under the knife. 1970 Cardinal red Judge 4 speed, next to go under the knife. 1979 El Camino SS clone, but a damn nice one. 2001 Ferrari 360 spider F1, Pozzi blue. DD, 2009 Silver Ice Trailblazer SS. Last edited by 2001WS6vert; 05-22-2012 at 04:04 PM. |
Thanks for the link. It says on the drivers side the front stud goes either in the first or second hole (depending on alt. bracket) which accounts for four studs unless my car had a stud in each hole. Does anyone know if the car would have used five studs?
Only 4 studs.
There are only 4 studs. Two on the passenger side toward the front. The other two are on the driver side. One in the way rear for the bracket that mounts the throttle cable to the carb and the other toward the second front for the alternator bracket. If you need to repurchase the bolts, a place in Virginia has them. I would need to find the catalog, along with the part number. None of the Pontiac places sell them. Let me know if I can help you any more. I am working on mine and drew a picture of the stud locations, so I DO KNOW where they go. Good luck on your project.
Just four studs with A/C . . .
1970: Driver's side, front to rear: bolt, stud, bolt, bolt, stud Passenger side, front to rear, stud, stud, bolt, bolt, bolt Check with our host here if'n you need new hardware!
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
What does the tcs switch bolt to? The 5th stud?
WWW.SUPERCARCREATIONS.COM |
