Old 10-03-2004, 09:42 AM
JonnyP JonnyP is offline
I've got a '64 droptop LeMans, and need to replace body wiring harness that goes across the floorpan under the carpet from fuze block to trunk area for the taillight harnesses to connect to. It's a 7-wire ribbon cable, and has the two power top motor leads attached. I've looked through the various aftermarlet catalogs and can find all the other repro wiring harnesses - except this one (!) Anybody know if this one is repro'd by anybody? Do I have to order one built for me from M&H? If I order from M&H, do they need the old one to pattern it after? Appreciate any help on this - Jon
Old 10-03-2004, 06:36 PM
jarhead's Avatar
jarhead jarhead is offline
I'm not aware of anybody offering a repro of that cable. Try clicking on the links at the top of the PY Online Forums page - http://performanceyears.com/links.htm. Go to Pontiac Related Business amd try http://mywebpages.comcast.net/gtopercy/ ; http://www.goatfarm.com/ ; http://www.frankspontiacparts.com/ or
http://www.newgto.com/
More pictures of my former Goat:
http://www.barrett-jackson.com/appli.../w_search.aspx
My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K
And in the 2008 Scottsdale auction, Lot #960 - $80K
Eventually sold by Brighton Motor Sports in Scottsdale, AZ - http://www.remarkablecars.com/ppads/...p/product/4844
Old 10-04-2004, 07:05 AM
HALFWAY's Avatar
HALFWAY HALFWAY is offline
Saw a couple on ebay a while back, I do have one but my grandfather punched a hole through it to left water drain from the floor pan. I was going to repair it but did find another during the restoration.
Basically it needs to have some of the insulation cut back and a metal piece soldered it then I was going to get some of the liquid plastic stuuf and coat the reparied area.
If you are interested in it, let me know and we can work out a deal.
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight!
Old 10-06-2004, 08:30 AM
HALFWAY's Avatar
Here is one for a convertible
http://cgi.ebay.com/ebaymotors/ws/eB...493086000&rd=1
Old 10-07-2004, 07:31 AM
Pecosbill's Avatar
The ribbon harness for a convertible is different from that of a hardtop or sedan. Be sure you get the right one. There are no repros out there, so you probably should go after the eBay one that Halfway mentioned.
Pecosbill
