400 RA3 .060 make into a 455. What do I need?
Dropped a valve in #4.
Sleaved the cylinder, blocks back to normal bored .060. (4.180) Can't find summits ''sealed power'' forged piston for the life of me. (just need one). Heck, I may as well turn this into a 455 if I have to buy 8 avalible pistons. Tell us how you built yours........................ |
I have 8 used pistons you need. 75 $ .060 400 TRW pistons.
To make it into a 455 you need a stroker kit. http://www.krepower.com/Pontiac%20Rotating%20Kits.htm https://butlerperformance.com/c-1459...ssemblies.html Go with a Scat forged crank. You won't have to have it re ground. Last edited by Dragncar; 09-29-2022 at 02:54 AM. |
The part number you need on the Summit site is L-2262f 060.
They are not back in stock until Oct 30. Your very lucky to have been able to save that block if it in deed is the correct code for a RA3 motor! I would do everything I could during this rebuild to not have the same failure this time around take place.
I do stuff for reasons. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
How were the fires this year? We did a lot better this year than all the others. |
Fires ? I live about a mile and a half from the ocean so big fires are not happening around here. Having a fair share of folks moving up here after their homes burned down inland or they are sick of the overbearing heat. If we want heat we just drive 20 miles inland, plenty of rivers up here to go swimming. Fire season is not over, plenty have happened in October, be safe. PM me your info on the pistons. |
Stand by....we're talking compression ratios on the other thread.
(didn't take that into account). Hold those killer pistons for me. Back shortly............... |
Who here has stacked 2 head gaskets to lower compression?
not a good idea.
carb tune, distributor tune and make sure the engine is running cool are your best options. might want to consider cam choice as well.
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
The Following User Says Thank You to 74Grandville For This Useful Post: | ||
That’s not a good idea but if you were to use gaskets to lower compression you’d use cometics . But at that point your better off just buying DSS dished pistons. Mostly because .060 w flat tops really kinda ups the compression. A Dss is made a 14 cc dish but because they are made to order he can do more if you ask .they are about $650 though which isn’t bad for a new dished pistons made to order .
Cometics can cost pretty good $$ especially the thicker versions
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
The Following User Says Thank You to turbo69bird For This Useful Post: | ||
School me on crank/block again, using the 455 crank in our 400 .
Machine shop said he'd have to reduce the rear main seals surface as well as the mains. Doesn't have the $700 stone (skinny stone) that'll fit the seals surface. Told him that stones likely $1400 bucks now..................... Not as simple as I thought. Glad I hadn't spent any cash yet. So, what to do with this wad of cash before the wife notices.................. |
But if you buy an after market stroker assembly it’s a drop in deal other than clearancing one little spot on the block. These are usually zero balance though so you need a zero balance fly wheel and balancers as well . I’m torn with what I’m doing on one of my engines also keeping what I have for rotating assembly or spending the money and going stroker set up. One thing I dint like about most of the stroker set ups is they are chevy rod length. 6.8 and I like the 6.625 rod because it Pontiac. The long rod has better dwell at TDC. But it’s still chevy **** in my Pontiac.
Typical BBC is 6.135. Chevy had a 6.405 rod as a "race" item once upon a time; and they were quickly discontinued. More likely, the aftermarket cranks are set up for Chevy journal diameter and width. |
Hike n mike donated 2 (two) 455 cranks at .020 under.
Hate to disappoint the guy. Something i learned sat. King bearing and other manufacturers make .030 and .040 under sized bearings now (or have for a long time) for our cranks. Boy.....back in the day, if yours was at .020 your crank was all done. Back to the stroker build up, Any other Ideas using one of the cranks in our 400? You guys are the best................ |
I have done a couple of these.Look into a Ohio crank 3in main rotating assembly.Getting a free 3 1/4 main cast crank still needs machine work to cut it down and cheapest is to also cut the Js to BBC because of so many rod choices.You will need to use a thrust bearing spacer with the 3 1/4 crank also.The one I’m doing now I will use 6.7 rods.Tom
$2475 complete forged Sam,bearings etc balanced etc.Tom
I guess, since I was going to end up buying 8 pistons instead of one (dealers won't split up the set) I may as well buy 455 pistons and have the crank turned.
Not simple . Not cost effective as I thought. Have to keep it a 400. Unless you can talk the shop into grinding it. I haven't given up. Hoping you guys have another way to make this crank work. But I think What's said is all there is for this, at this moment. Old timers....back in the day started stroking these before you could buy scat's That time seems to have past. Heck.....we're down to one machine shop in town too............... |
Thread Tools | |
Display Modes | |
