Old 05-01-2022, 12:49 AM
ta man ta man is offline
Originally Posted by Gach View Post
Definitely a good day the numbers definitely look real good and promising. That sounds like allot of slippage. Interesting see what she does with the Continental. Bet it feels real good getting back out there
Felt great! A few of the track guys were surprised how hard the car was leaving!
  #62
Old 05-01-2022, 12:51 AM
Originally Posted by slowbird View Post
Making progress! I was wondering how the UCC converter would run, personal think the continental will be the one to stick with
We will find out in a few weeks!
  #63
Old 05-01-2022, 12:58 AM
Gach's Avatar
Gach Gach is offline
I’ll bet gear change had allot to do with that. Now that you have a nice tight trans. Can’t wait see if The continental convertor changes things. Can you give me your cam specs. And car weight.
PS what stall is Continental converter vs what’s in there now
Old 05-01-2022, 07:09 AM
Cliff R's Avatar
Cliff R Cliff R is offline
There will always be a trade-off between improved 60' and short times vs being coupled tighter on the run and applying more power to the track for the rest of the run.
I tested and helped develop higher stall versions of the Continental 10" unit and found out exactly what you are. I was using 28" tall tires and 3.42 gears when the converter testing was done. I saw improvements in the launch and 60' times but fell off a tad in MPH on the top end. I was also seeing higher RPM's on top end. The really "loose" versions I tested didn't work well at all with 3.42 gears and it felt like the trans was actually slipping on the run (sound familiar?). RPM's stayed really high and I could no longer feel the shifts either.
So basically up against 3.42 gears I was not able to see the benefits of higher flash stall and leaving harder on the time slips.
I really needed to change to taller rear gears in conjunction with the converter changes to get the engine up to the shift point quicker and spend more time at high RPM's on the run vs "lugging" the engine as much at lower RPM's. Higher RPM's also help "lock-up" the looser converters which also improved both ET and MPH with them..........
  #65
Old 05-01-2022, 09:46 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Definetly headed in the right direction.
Keep up the good work.
Go fast, see Elvis!
  #66
Old 05-01-2022, 01:50 PM
Cam is a 236/246 with a .391 and .400 lobe lift with HS 1.65 rockers 112 LS
Continental was a 3200 vs a 3800? (which I think is actually lower) UCC
3700lbs (need to reweigh)
The Following User Says Thank You to ta man For This Useful Post:
  #67
Old 05-01-2022, 02:01 PM
Cliff you have always ran 255/60's? So your car would be similar for effective gearing or close. Yes the top end of the track it just doesn't feel right..I know if the convertor is slipping its building heat..not good..my trans guy will kill me..
It will be interesting how the Continental performs once again with another combination of parts. It has been behind 4 different 455's from a iron headed mild 375hp to the current engine. It has also been used with a 308,342 and soon a 373 rear..its amazing how it works well every time.
Maybe I should start another thread when I swap the trusty old convertor in.
  #68
Old 05-01-2022, 02:17 PM
Yes even if there is issues as long as there is progress. A guy at the track said to my niece..he has that street car dialed in...She told the guy..he is still pissed off at it..its off.
  #69
Old 05-01-2022, 03:13 PM
Gach's Avatar
That cam going to want to make peak torque at around 3500 Pontiac’s like tight convertor, as a rule. So The continental even though it’s 3200 it’s going to lock up around 3500. Were as the UCC being 3800 probably locking up around 4000. Probably what your feeling.
I’ve run those cam specs that’s awesome cam.
Old 05-01-2022, 04:54 PM
A nice picture from yesterday, shows the caltracs are working.
  #71
Old 05-01-2022, 05:16 PM
slowbird's Avatar
slowbird slowbird is offline
Id be very surprised if it makes peak tq way down at 3500.
How did the engine run that you ran a similar cam in?
  #72
Old 05-01-2022, 06:06 PM
Gach's Avatar
Oh yes definitely working good
Old 05-01-2022, 06:09 PM
Gach's Avatar
Going to interesting see if you pick up anything with Continental converter, it’s a tough call. Sounds like it’ll definitely be tighter.
Old 05-01-2022, 06:22 PM
Gach's Avatar
Oh so you haven’t gone to 3.73 gear yet. For some reason thought you had. One more question do you know what rpms your going though the traps at
Old 05-01-2022, 10:25 PM
No that is just my bad wording..I should have said " and soon again with a 373 gear"
Going thru the traps at about 6200rpm with the UCC
  #76
Old 05-01-2022, 10:26 PM
I'd have to check with Dave Bisschop I would guess peak torque is around 4500rpm.
  #77
Old 05-01-2022, 10:53 PM
Gach's Avatar
391 and .400 lube
Ok, I was looking at duration, now that took second look I see the lube and what the lift is, works out to be, Yeah 4500.
The cam with same specs, I ran ( same duration on 112 ) had no were near that lift.
Old 05-01-2022, 10:55 PM
slowbird's Avatar
Id agree couple hundred one way or the other from 4500rpm.
  #79
Old 05-01-2022, 10:58 PM
Ya it has a little bit of lift...that is what makes it a real pussy cat car to drive..mild duration good compression but good lift.
  #80
Old 05-01-2022, 11:55 PM
Gach's Avatar
645/660, if my numbers are right…yeah that’s allot. For some reason in my mind I’m think with that duration little hyd cam, maybe 520 lift, don’t mine me. Really nice combo. So its a hyd roller.
