#161
Thanks..I will check them out..there are a few other valvespring setups like this with no issues but nice to double check.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 10-06-2022 at 06:36 PM. |
#162
Not saying it's an issue but worth checking. Since you put 3.73 gears in and your now spinning it high and in the higher rpm range more but have lost hp/mph it's seems like a place to look.
#163
About 15 years ago, 70 GTO , 3780 race weight.
12.4:1 462, 270/280@ .050 solid roller .660 lift. .Victor intake with 2" Super sucker. Race ported Es.T400/ 8" PTC 4500 stall/ 411 gear. Consistently ran 6.6@ 102 1/8 mile. Changed the 2" Super Comp to 1 -3/4 Hedman Hustler, lost .2 (6.8) in the 1/8. Also noticed that the engine rpm worsened. Changed back to the Super Comp and picked up the time. Last edited by 68WarDog; 10-06-2022 at 07:08 PM. |
#164
Well it's what I'm thinking is something is off or holding it back.
#165
Theoretical rpm across the line with 3.08 gears and 125.64 mph is 4644 rpm, actual at 5300 rpm = 14% slip.
Theoretical rpm across the line with 3.73 gears and 124.60 mph is 5577 rpm, actual at 5850 rpm = 4% slip. These are calculated without assuming tire growth.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#166
Heading to the dragstrip Saturday. I believe Andy and a few other local Pontiac guys are coming as well.
I normally always just make one change but time is running out this year, so I made quite a few little changes since last outing. Retarded the cam 2 degrees hoping to shift the power curve up and gain some horsepower up top. Installed a new set of Hyd lifters I had on the shelf, had the odd ticker now and then. (maybe bleeding down slightly?) Went back to 10w30 vs the 15w /40 oil. It is cooler now so I don't want the thicker oil takes too long to thin out. Dropped oil volume down 1/2 quart and may go another 1/2 to avoid windage problems. Set up the engine to use either a one inch or 2 inch spacer and also built a new airpan assembly for the 2 inch. I currently have a 2 inch HVH Super Sucker tapered 4 hole spacer on the engine. Weather looks good and as long as we don't have a strong headwind should be a good day. I'm hoping all the little changes are a step in the right direction.
466 Mike Voycey shortblock, 310cfm SD KRE heads, SD "OF 2.0 cam", torker 2 373 gears 3200 Continental Convertor best et 10.679/127.5/1.533 60ft 308 gears best et 10.76/125.64/1.5471 Last edited by ta man; 10-21-2022 at 01:27 PM. |
#167
Air Pan picture
Sent from my BBF100-2 using Tapatalk
#168
Sounds like a well thought out strategy. Good luck!
#169
What brand lifters you install?
#170
A set of Comp 857's that I had..they are different then my first set.
#171
Are they the newer ones or the older ones with the lower oil band?
#172
Go, Ernie. Go!!!!
#173
Newer with the higher oil band.
#174
Good luck TA! I'm surprised to hear you are using a 4 hole spacer, you ever try an open one?
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
#175
Weather looks great up there today with a healthy tail wind. Should be interesting.
Best conditions are this time of the year and the tracks around here closed for the season already.
#176
I usually use a one inch open, after the track results Id like to try a 1.5 and a 2 inch open..the 2 inch supersucker was out performed today by the one inch open..
The Following User Says Thank You to ta man For This Useful Post: | ||
#177
Andy ran a new best of 10.76 I managed a 10.78..will post my timeslip when I have more time to add to the post. I did gain more mph even with the headwind..so a positive result.
#178
Correction Andy ran a 10.69
The Following 2 Users Say Thank You to ta man For This Useful Post: | ||
#179
We had a great day . I’m just thrilled…. Best part is not breaking anything and driving home.
The Following 4 Users Say Thank You to Torquewar For This Useful Post: | ||
#180
What track were you running on?
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
