Seating front oil seal.
What would you use to seat (tap in) the front oil seal with in car timing cover ?
Thank you. |
If still installed on the car, I use a 3/4" drive, deep wall socket. A cheaper alternative might be a length of the correct size PVC pipe.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
I’ve used a threaded cast iron pipe that fits over crank snout, with flange on one end
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
The Following 2 Users Say Thank You to grivera For This Useful Post: | ||
Thread Tools | |
Display Modes | |
