Old 02-10-2019, 02:30 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Default Vent window channel weatherstrip
Assembling my vent windows & am wonder if those of you have have changed the channel seal, & left the original lower section. Seems it was built that way on purpose, maybe to allow the window to roll up/down easier? The replacement is full length, but I am planning of cutting it off to fit like the originals as the lower section is in great shape.
Any thoughts?
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 02-12-2019, 10:47 PM
PurelyGTO68 PurelyGTO68 is offline
I cut mine so it matched how the original seal worked. The felt lining on one assembly was in very good condition so I reused it. The other vent window assembly was in poor shape so I scraped out the lining and installed new.
I bet if you shoved the seal into that lower channel the window would bind up. It's a very tight fit. I think everyone has to cut theirs to match the OE length.
Old 02-13-2019, 07:46 AM
68ragtop's Avatar
Thanks! I ended up doing the same. The more I thought about it there was no point in a seal like that below the top of the door seeing the lower section was in great shape. Looked like the only way it could be used full length was to remove the lower existing channel by drilling out the rivets anyway & I didn't want to do that. I did put a little weatherstrip adhesive at the bottom of the new top section to keep it from moving.
Both side of mine looked to be in nice shape, but boy they were hard as a rock. Had to break them out of the channel in pieces. The ones on the leading edge of the quarter glass were the same way.
89 Trans am GTA
Old 01-09-2023, 12:47 PM
rasilverbird rasilverbird is offline
Any thoughts?
Where did you get this piece? I'm looking for it now.
1968 GTO - 400/400 - Currently being rebuilt - 455/T56
1996 WS6 - LTI M6 - Sold 5/11
1979 Trans Am - 403/Auto - Sold 12/18
Old 01-09-2023, 02:57 PM
OG68 OG68 is offline
If you're referencing the window assembly, which side do you need and Hardtop, Convertible or Sedan?
Firebird or A/B Body?
Never mind, just saw your second post.
So Hardtop or convertible.?
2007 Cadillac SRX
Old 01-09-2023, 09:34 PM
gto4evr gto4evr is offline
I've got an NOS one of these laying around somewhere, not sure if it's left or right but I'm thinking it's the right side since the pair of repops I bought for my dad's 68 was because his driver's door weatherstripping was all broken up. Anyways, the NOS one is definitely only the small piece, not a full cut to length item like the repop. I also left the original lower section in when I did his car, it looked way too tight to remove the original and get that piece in and have the glass still move after the squeeze. The repop upper molded piece is pretty sad compared to an original. I'll have to find that NOS one.
Old 01-10-2023, 04:18 PM
Hardtop. Can't find that window guide, and need it soon
Old 01-10-2023, 04:40 PM
Hmm. I thought you were referring to the vent window frame itself. I tossed the channels last spring.
2007 Cadillac SRX
Old 01-10-2023, 06:37 PM
what exactly are you after here? the channel that's part of the vent window frame?
Pretty sure I've got a pair of vent window assemblies somewhere in my piles out in the sheds.
Old 01-11-2023, 10:52 AM
No, just the guide. I think I've found it here:
https://www.yearone.com/Product/SearchTarget/436099
