Old 01-05-2021, 08:52 AM
chrisp chrisp is offline
Default Z-bar/ clutch pedal repair bushings
Z-bar/ clutch pedal repair bushings these oilite flange bushings repair the wearable egg shaped holes . The elongated holes would need to drilled to 3/8" to accept the repair bushing , check both holes on z-bar & the clutch pedal hole as well . Welding is only required to fix the male ends on the z-bar linkage from the pedal to z-bar ends & clutch adjustment rod end if worn then file fitted to accept bushing . Also makes a nice smooth pedal / non binding . $30.00 shipped for 3 pcs. as per required . These fit 5/16 male ends . If the male ends are good then no welding is needed .
Old 01-16-2021, 08:36 AM
Bump
Old 02-27-2021, 09:06 AM
Fits 5/16 [0.3125] ends only set of 3 $30.00 shipped USPS with tracking & delivery confirmation.
