Pig rich. Very Funny. My chevy buddies seem to think burning your eye's rich is better. I just nod my head agreeingly.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
These the air cleaners you are referring to.
http://i514.photobucket.com/albums/t...m/P8050026.jpg http://htsmall.ecklersfirebird.com/a...u/75-41652.jpg http://cdn3.volusion.com/klmat.yytxn...jpg?1425797380 I did try this one but didn't have the bubble top to go on it & I had to space it up about 3/4 in. as I have the rear choke pulloff on my carb. Didn't like it. It was down about 5-7 hp from the flat base. |
Actually burning your eyes is more of a lean condition..
Rich OR lean, it's a MISFIRE condition.
Anybody tried these on a Qjet.
http://www.speedwaymotors.com/Sure-S...Inch,1601.html These must be the same? https://allstarperformance.com/produ...LL26094&add=no |
Not tried one on a Q-jet, but they work good with Holly's.
Brings up a question, has anyone actually tested the factory drop bases and "bubble top" pieces that came on TA's against more conventional open-air elements or factory dual snorkel intakes? The TA intakes look like the ones in the links 77Cruiser posted. With the short filter used in these cars they seem mighty close to the top of the carb, but then they were engineered by Pontiac so maybe not so bad?
1969 Lemans vert, matador red, 462 CI, 3.07 12-bolt posi 1974 455 TA, admiralty blue/red interior HPP "cover car" - sold "The best way to show a car is to drive it" |
Speaking of factory set up's, any comment on the factory set up on a 69 GTO Judge with RAMAIR as far as the stock air filter and cover?
color me gone |
Link to a previous discussion where I tested some different air cleaner bases and elements: http://forums.maxperformanceinc.com/...=filter&page=2
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
Did you ever try it w/o an air cleaner?
You made 476 on the Dynojet. Did you ever have it on an engine dyno?
I'm currently running a Spectre Cowl Air Cleaner with a 3.75 inch high filter..which works pretty good as far as bringing in cold fresh air.This air cleaner has a big drop to it but a nice dome top...but maybe it too is giving up a little?Next year I will experiment with my Moroso air pan which actually sits about 1/4 inch above the carb with a nice gentle radius... |
I did test without the filter. The loss was typically 2 to 5hp. I later installed one of the AirAid semi-conical filters (14" at the bottom, but maybe 10" or so at the top, and about 4" high, which seemed to perform a tad better at the track than the conventional 4" tall K&N with a rounded top cover.
I'm sure I have a calibration issue with my carb, just have to figure it out. |
I can safely say at this point that I've done more back to back dyno and drag strip testing between Holley's and Q-jets than most who will read this.
On dual plane intakes I've never been outran by any square flange carb, Holley, Quick-Fuel, Demon, etc. On single plane intakes we've had some very "spotty" results. Most if not all of them will REQUIRE a spacer to get the carb throttle plates up out of the plenum some for best power. The q-jets and Thermoquads can really take a back seat on a single plane intake without a spacer. The most dramatic deviation I've seen was just over 100hp trying to run a Q-jet on a single plane intake with no spacer at all. That's for sure the extreme range, but most will be down 15-25hp if you don't use a spacer of some sort to get the huge secondary throttle plates up out of the plenum area. Track testing verifies the dyno deviations, but ET and MPH are not as dramatically effected by the dyno differences as we are only talking about peak HP, not torque and average power. For sure single plane intakes have ran slower in 60' times on every test I've done comparing them to a dual plane intake, but in most cases, if topped with at least a 1" spacer then will run more MPH. Same thing with drag strip testing a single plane intake with and w/o a spacer. To date they have ALWAYS ran quicker ET and MPH with a spacer, and in some testing as quick as .2 and 2-3mph vs not using any spacer at all......Cliff
Holley.
This is the spacer I'm using, .75 thick.
#38
I was hoping you said Qjet.
With the adapter plus the gasket I was an inch above the intake. |
#39
That adapter is a nightmare for a any type of spread bore Carb!
I tested one out many Moons ago when I first got my flow bench . The set up was a iron head ( small block Chevy ) ported to 250 cfm@28" , a early square bore single plane Manifold and a 750 Q-jet. In short with the rate of taper that adapter has on the secondary side the motor would make the same level of power with square bore 600 cfm Carb from what findings showed. And this is just in terms of dry air flow, I am sure a wet flow test would show a nightmare condition also at wide open throttle and a 600 cfm Carb could end up making more power depending on the size motor and its air flow demands!
#40
Mine is blended into the intake a bit, don't know how much it helps.
