Old 05-29-2021, 09:24 PM
CraigG.'s Avatar
CraigG. CraigG. is offline
Default Where can I buy THICK cork pan gaskets for a steel pan and Turbo 400?
Hey Everybody,
No response from the race forum - so I thought I would try you guys.
Thanks Guys, Craig
Old 05-29-2021, 09:54 PM
Why, is your pan bent and that’s why you need such?
Why not layer 2 up?
Old 05-29-2021, 10:30 PM
CraigG.'s Avatar
I just want the thickness recommended by good transmission builders - not the thin kind that usually comes from most parts stores.
Thanks, Craig
Old 05-29-2021, 10:40 PM
pastry_chef's Avatar
Summit Racing has various types and brands available.
Any large parts store should have at least a few choices.
Old 05-29-2021, 10:58 PM
vertigto's Avatar
vertigto vertigto is offline
Consider these fiber gaskets from ATI, like Farpak.
https://www.summitracing.com/parts/ati-403550
Old 05-30-2021, 07:12 PM
Dragncar Dragncar is offline
This
https://www.summitracing.com/parts/l...+5ba2884df3acb
Old 05-31-2021, 07:33 AM
taff2's Avatar
taff2 taff2 is offline
We try not to use the cork gaskets -too easy for the customer to overtighten. We use the thinner hard fibre gaskets, stick it to the pan only with a thin bead of Grey Abro or Permatex if the pan is a bit beat up.
Old 05-31-2021, 08:47 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Cork gaskets squeeze out and fail, always have. They will do a very good job of sealing things up if you are very gentle when tightening the bolts but eventually the pan will start leaking as they will not hold their shape in long term service. So basically they just continue to squish out and end up failing where they are punched for the bolt holes.
I use and recommend the fiber gasket, gently glued to the pan with a small amount of RTV so you can remove the pan and use them over and over again. I've never had one drop of oil get past the fiber variety and use them in all the TH400's that I build here.........
Old 06-01-2021, 06:00 PM
CraigG.'s Avatar
What do you think of this gasket for a stamped steel pan and using B and M synthetic transmission fluid?
https://www.summitracing.com/parts/mrg-8691
Thanks, Craig
Old 06-07-2021, 09:43 PM
CraigG.'s Avatar
Hey everybody,
Thanks for your help and per several positive suggestions from different guys the one I remember recently is Cliff - to go with a Farpack Fiber gasket from global transmission parts in Ohio – $3.95 plus shipping!
I also got a new TCI replacement Transmission brake solenoid.
Take care, Craig
