Old 04-15-2024, 08:55 AM
RAIIIJudge's Avatar
RAIIIJudge RAIIIJudge is online now
Default Water Pump Going South?
hi, all,
made this video last October while checking my hideaway install that captured a high pitched knocking I've heard before while under the hood. you can hear it clearly around the 5 sec mark. is this the water pump?
https://www.dropbox.com/scl/fi/xxp9i...ruqyekyzo&dl=0
appreciate the ears,
mike
MA
Old 04-15-2024, 09:22 AM
Run it with the belts off and see if what you are hearing goes away.
Clay
Old 04-15-2024, 11:29 AM
I have not watched the vid, but I have heard such sounds if you have a auto trans and the flexplate is cracked to one degree or another.
If you have a clutch fan also check that the fan itself does not wobble on its shaft.
Old 04-15-2024, 12:48 PM
RAIIIJudge's Avatar
4spd , no clutch fan
thanks, fellas
