Old 04-27-2015, 12:10 AM
Bill Hanlon's Avatar
Default Is this a farmer fix?
I've been helping a guy with a '58 Pontiac troubleshoot his fuel gauge that always reads empty. After I got him to remove the wire at the sending unit and the gauge finally read full I told him to remove the sending unit and check it with an ohm meter at empty, half and full. It read correctly, but the "float" was made from cork. I'm guessing the float was saturated with gas and has sunk, always reading empty.
Did Pontiac use cork floats in the '58 gas tanks or is this a rather amateur attempt at a fix?
Old 04-27-2015, 12:32 PM
Here is a picture of the float.
Old 04-27-2015, 05:13 PM
indymanjoe's Avatar
indymanjoe indymanjoe is online now
Cant answer,but i have seen an 1157 lite bulb wired as a float on a sender once.
Old 04-27-2015, 05:26 PM
Jeff Hamlin's Avatar
It should have sort of a clear sealer over the cork,
I've never seen a square one most are round but it sure could be correct.
Old 04-27-2015, 09:24 PM
Now that's my kind of a kludge.
Old 04-27-2015, 09:58 PM
Ben M.'s Avatar
Ben M. Ben M. is offline
Quadrajet float is another good idea...
Old 04-28-2015, 09:42 AM
60man's Avatar
60man 60man is offline
My 60 float is square...
ECM member.
MANDRA
Old 04-28-2015, 11:58 PM
Alvin's Avatar
Alvin Alvin is offline
Cool
Old 05-14-2015, 02:43 PM
Teej's Avatar
Teej Teej is offline
I had to replace the float on my '58 wagon. It was square cork. Saturated. I cut a segment off of another sender for something I had lying around it's worked great since. Good thing too as the wagon ones are different shaped and hard to find.
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
