1100832 dates
What has everyone seen for available dates for the 832 alts?
The earlier (68) dates seem to be more commonly found then the Jan and later ones. From what I have seen, there are 3 or 4 Jan dates. There is supposedly a Feb 1 or 2 and there is a July G 24. On on another post I saw that someone had an Aug date? A lot of early TA owners that I have spoken to, say that their cars have Jan dated units. Which leads me to believe that Mar thru June units weren't made? |
My TA was made Oct. 22nd of 69 and has a 9G24 dated 1100832 alternator. It also has the back half for a 1970 which I have seen on several other late cars.
The Following User Says Thank You to Ponimino For This Useful Post: | ||
The first versions of the internally regulated alternator had a very high failure rate. Thus, most failed and were replaced early on making them hard to find today.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
I realize this is a really old thread/ topic but just curious what replaced them? Did they switch the car over to a external regulated alt? (I have heard that but can’t confirm it) Or a superseded part number internal SI alt?
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
I thought the internally regulated alternators weren't used until the 1971 model year.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
1970 was standard on Firebirds.
1969 was optional on Firebirds.
