Old 07-14-2021, 11:39 PM
Terry M. Hunt Terry M. Hunt is offline
Default 66 upper control arm bushings
Forgot to make a note of this before removing old bushings. The steel can on the new bushings is the same diameter end to end. There is no larger diameter step in the can up near the flange on the end. For this reason, I’m assuming that the new bushings should be pressed all the way into the control arm until the flange on the bushing contacts the collar on the control arm hole. Is that correct?
Terry Hunt
"He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr.
Old 07-16-2021, 01:21 PM
Never mind. Did some measuring that confirmed that the bushings need to be pressed all the way in and that’s how I installed them.
Terry Hunt
Old 07-16-2021, 02:08 PM
chrisp chrisp is offline
Yes & do not tighten any bushings until on the ground with all weight applied.
