OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-12-2012, 03:12 AM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Default Radiator Hoses
Cammer 6 and I both hate the wormy looking radiator hoses so I am looking for better ones.
I have found that a NAPA 7322 lower hose fits perfectly. I was sent a Tempest upper hose 8484 but I do not have a Tempest.
I am looking for a upper hose for a FB with power steering.
Any tips or part numbers?
Old 08-12-2012, 09:03 AM
Cammer-6 Cammer-6 is offline
do yo have an old one to take to Napa and match up?
Ive had good luck doing that and cutting the section out of a hose to fit.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-12-2012, 11:36 AM
PMD1969's Avatar
What I do have is the wormy ribbed hose that has been on there for 25 years. That's it.
Old 08-12-2012, 12:00 PM
PMD1969's Avatar
Pictures:
Lower Hose NAPA #7322 for Firebird
Old 08-12-2012, 12:02 PM
PMD1969's Avatar
Upper hose possibly for Tempest Lemans
Old 08-12-2012, 04:30 PM
PMD1969's Avatar
Success!
I took a piece of card board and traced out the old crappy hose. The guy at NAPA (Thanks Bill) was nice enough to let me go back behind the counter and look through hundreds of hoses.
This is what I found #8602 works well but you have to cut the ends off as the middle piece is what you want. IIRC it was $17 and looks a ton better. This is for Firebirds.
Old 08-12-2012, 05:49 PM
Jeff Hamlin's Avatar
Thumbs up Good Score
Your were on the right track.
The first pic shows the 8484 after it was cut to fit.
Second pic is the overlay.
3rd pic is an NORS hose I found and the last pic is another hose I found that can work as you have done.
Old 08-12-2012, 06:13 PM
yep Ive done this many times,saving the NOS ones for the show cars only.
The other piece of mind is youre using fresh rubber not 40+ yr old stuff.
now find some bypass hose thats GM and not fuel line.........
Old 08-12-2012, 07:02 PM
PMD1969's Avatar
Hmmm... well I would have loved to have had those phootos befores I started. I was really concerned about the power steering pulley since it seemed to be so close to the hose. The crappy one did a good job of getting around it so I just copied it.
Didn't know the NOS looked like that
Well I am hoping that the lower will be somewhat OEM correct and just fit. Now I just need to find a receptacle to catch all of the fluid and get some new radiator fluid.
Thanks for the pics! Please keep them coming
Marc
Old 08-12-2012, 07:05 PM
PMD1969's Avatar
I am afraid to ask but how much would a set of upper/lower NOS hoses cost for a 69FB Sprint.
Old 08-12-2012, 07:48 PM
Looking at your pic I think you would be fine as is.
I think your upper hose would not be the same as the A-body but not 100% sure.
Your rad looks to be slightly wider left to right.
I would concur with Cammer on the use of NOS hoses,
not something I would use on a car driven.
Old 08-12-2012, 07:59 PM
PMD1969's Avatar
How would I check to see if the radiator is correct? I do know that it was replaced in 1982. The other items related to it are that the power steering cooling lines are mounted in three different ways. Mine is on top, one internet guy is in front and another internet guy is in the back.
I have never taken this car to a show and at this rate probably never will! LOL Even if I wanted to show it I am a looooooong way away from even getting somewhat close to the cars I have seen at those events.
Mine is a driver.
Old 08-12-2012, 08:12 PM
Your rad looks correct to me.
Also ran a quick search and looks like you’re not too far off with the consensus on the upper hose for FB.
Old 08-12-2012, 09:09 PM
since I have 2 68s not sure I want to let go of any 67-9 NOS hoses.
I think one of my 68s still has the ones it came with over 44 yrs ago
Old 08-12-2012, 11:12 PM
PMD1969's Avatar
Fair enough.
Share some pics of your show winners with us.
Old 08-13-2012, 09:15 AM
Yes Please do.
Old 08-13-2012, 09:22 PM
Jeffs the one with all the trophies
Im too busy building everyone elses cars to finish mine.
