clutch problems
trying to awake my barn find 69 judge ( my barn for 30 plus years ) put a new clutch , pressure plate , throw out bearing kit from summit in it but don.t have enough pedal travel to release it. Are there different length throw out bearings like chevy used to use other wise the clutch fork might be the problem . it actually hits the bellhousing. thanks
You may need a longer ball stud. Is this a stock set-up?
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Yes there are different length throwout bearings. All the Pontiac ones I have seen are taller. Do you still have the old parts to compare them?
Adlustable ball stud could be used as mentioned to help compensate for the shorter TB but it would be best to just get the correct throw out bearing. |
the motor and trans was in it but not running wasn't a gto motor but still had the 3 speed top loader trans
3 and 4 speed used identical clutch and linkage. I concur that sounds like you need the thicker throw out bearing
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
Thread Tools | |
Display Modes | |
