Old 11-05-2021, 04:09 PM
NYGTO's Avatar
NYGTO NYGTO is offline
Default 1965 GTO Throttle Return Spring
If anyone has a yellow 1965 GTO throttle return spring (G.M. only) in good condition or better they would sell please P.M. me Thanks
Old 11-08-2021, 11:02 AM
NYGTO's Avatar
with all the tri-power conversions from AFB 4bbl. I'm thinking they would be laying around somewhere :--)
Old 11-18-2021, 09:36 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Not sure what you mean by this ^^^^^ because 4BBL. and Tri-Power use the same yellow throttle return spring for 1965.
ID:	578070   Click image for larger version
ID:	578071   Click image for larger version
Old 11-19-2021, 06:02 PM
NYGTO's Avatar
My mistake and I'm glad you pointed it out because it'll keep someone from getting confused while setting up a carb. Thanks (and I found my original)
The Following User Says Thank You to NYGTO For This Useful Post:
