Old 11-25-2021, 09:28 AM
lew4ut lew4ut is offline
Default vacuum advance question
i am new to the forum and was wondering if someone could give some advice on the correct installation for the distributor vacuum advance for a 1969 judge with manual 4 speed transmission. Any help would be appreciated.
lew4ut
Old 11-25-2021, 12:22 PM
OG68 OG68 is offline
Ported vacuum from the upper right front (driver side) of the carb.
And welcome
ID:	578528   Click image for larger version
2007 Cadillac SRX
Old 11-25-2021, 01:11 PM
Thanks very much.
Old 11-25-2021, 01:58 PM
padgett's Avatar
padgett padgett is offline
Ported vacuum was for emissions only and one reason that some cars diesel when shut off.
Web Site
Old 11-25-2021, 02:55 PM
Where do you suggest I get the vacuum for the distributor then?
lew4ut
Old 11-25-2021, 07:17 PM
Ab69 Ab69 is offline
Distributor vacuum control valve was used for the manual transmission, it will use both ported and manifold vacuum. That is if you have the two hose hookup on the distributor vacuum.one in the front and one in the back. Otherwise manifold valve hookup if you only have the one distributor vac connection.
Old 11-27-2021, 07:24 AM
Thanks.
Lew4ut
Old 12-02-2021, 12:51 PM
tekuhn tekuhn is offline
My personal preference is full vacuum at idle. I haven't had an engine yet, that I didn't feel like it ran better. It just sounds like you're able to achieve the same idle speed with less effort (judging from the exhaust note). It allows a smaller carb throttle blade opening for better signal to the idle circuit in the carb, and as mentioned, less chance for dieseling on shutoff.
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
Old 12-03-2021, 06:36 AM
Thanks for all your replies and suggestions.
lew4ut
Old 12-11-2021, 01:22 PM
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
Both of my 69 4spd cars didn't have any vacuum control valve. It was just one hose from the vacuum advance to a metal hose and then another rubber hose to the left bottom of the Qjet as the factory photo shows.
Old 12-12-2021, 06:27 AM
Thumbs up
ok Thanks
Old 12-13-2021, 10:25 AM
lew4ut, Distributor vacuum advance valve may
only have been used for the early 69 manual ram air III .
Old 12-14-2021, 06:56 AM
Ok, Thanks My 69 was a late build; 4th week of July.
