Driveshaft removal
Trying to get the drive shaft removed from my 77 lemans any thoughts besides the back bolts
Sent from my SM-S111DL using Tapatalk |
Have you run into difficulty? This is normally pretty easy stuff. Did you try giving it a little smack forward? They can hang up in the yoke...
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Have a old yoke handy to put in the trans when you pull the shaft!Or drain it first.Tom
[QUOTE=Flashflood;6231748]Trying to get the drive shaft removed from my 77 lemans any thoughts besides the back bolts
Sent from my SM-S111DL using Tapatalk[/QUOTE Are you using a hoist or is the vehicle on the ground? If on the ground make sure you’ve blocked the wheels and have set the parking brake so that the vehicle can’t roll away when the driveshaft is out. Once the shaft is out having the transmission in park (or In gear on a manual trans) does nothing to stop the vehicle from rolling away. Safety first. |
The Following User Says Thank You to 1969GiPper For This Useful Post: | ||
Got it was a little cab on the u joint next stop removing engine parts
Generally recommended to mark it so you can put it back in in the same position.
Greg Reid Palmetto, Georgia |
