Old 02-28-2021, 09:24 AM
Nicks67GTO Nicks67GTO is offline
Default Edelbrock D port accessory bolt hole layout needed
Hey guys. Im working on a type2 power steering pump solution for my 67 GTO. I have edelbrock D ports but they're in the car so it's kind of hard to get a really accurate measurement on bolt hole spacing. Does anyone have a file with the holes laid out by chance? I'm using a later 11 bolt waterpump if that matters.
-Nick
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies
- Build Thread
http://forums.maxperformanceinc.com/...615847&page=23
Old 02-28-2021, 09:46 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I have mine off of the engine. What do you need exactly?
Old 02-28-2021, 10:25 AM
This is my mock up template. I need exact center to center x/y axis distances between the 3 holes I'm using for standoffs.
- Build Thread
Old 02-28-2021, 11:02 AM
Skip Fix's Avatar
Skip Fix Skip Fix is online now
Nice!
Skip Fix
Old 02-28-2021, 12:55 PM
Skip Fix's Avatar
My round port E heads have an identical bolt pattern to a late 6X head if you have one around.
Skip Fix
Old 02-28-2021, 02:11 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
I'm thinking I read that the bolt dimensions are the same as on a SBC. Thinking you can use the set-up already being used on the funny looking little orange engines.
Old 02-28-2021, 02:22 PM
Bnick166's Avatar
Second thought... I think it was the vacuum pump mount for a SBC...not power steering.
Interesting read and Ideas...
https://www.pro-touring.com/threads/...ing-Pump/page2
Old 02-28-2021, 04:14 PM
Tom Vaught's Avatar
Boost Engineer
I can give you that info Tom V.
Nick here is the bolt hole numbering for conversation:
Hear is a picture of the bolt holes on the Drivers Side cylinder head for some stock Pontiac heads and also Edelbrock E-Heads.
The holes would be numbered:
Bolt hole (Top left of head) = #1
Bolt Hole (Top left of Head Core Plug) = #2
Bolt Hole (Bottom left of Head Core Plug) = #3
Bolt Hole (Bottom Right of Head Core Plug) = #4
Bolt Hole (Bottom left of Head close to head gasket) = #5
Bolt Hole (Bottom right of Head close to head gasket and exhaust gasket ) = #6
Tom V.
Call me Nick and I will give you the locations for the holes you need.
Name:	cylinder head bolt pattern drivers head.jpg
Old 02-28-2021, 05:47 PM
Ok, based on that Tom, here's the holes I'm using to mount. I need measurements center to center on
-2 to 6
-6 to 5
-5 to 2
- Build Thread
Old 02-28-2021, 11:17 PM
Tom Vaught's Avatar
Boost Engineer
Thanks for the phone call.
Glad to help you out.
Tom V.
