ram air manifolds
ok got a set of ram air restoration manifolds for a sec gen bird.
they came with regular header gaskets instead of the original style so should i use the header gaskets or go get some original gaskets. thanks |
manifolds
no advice on this ?
I have used both they both do well. Right now I'm using header gaskets trimmed so you can't see them.
I use header gaskets as well. No issues...
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
I used the factory type steel shim gaskets. I never had any problems with them.
This and little high temp silicone. The critical thing is the surfaces have to be flat no matter what you use.
The More People I Meet, The More I Love My Dogs! |
I used header gaskets for a short time with no issues and then I had my engine rebuilt and my builder put the original metal gaskets on and have had no problems in nine years and 20k+ miles.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
IMHO, it's hard to beat using the factory implementation.
I use copper.
Steel is all that is needed.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
I have used steel Felpro never any problems!
I Bleed Arrowhead Red, 64 GTO 389 Tri Power 4spd Nocturne Blue Poly 70 GTO 400 4spd Palladium Silver 70 GP 400/4 spd triple Black 71 T/A 455 4spd Cameo White 01 T/A Bright Red 4L60E Ram Air WS6 02 TA Navy Blue Metalic 6 spd Ram Air WS6 |
I have almost always used OEM steel gaskets.
IIRC I did try header gaskets once, but after a short while they blew out (probably because '70 RA manifolds only use three bolts to hold the manifold to the head.
Can the steel gaskets be used when putting the iron manifolds on aluminum heads?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
