Old 07-16-2021, 01:20 PM
Scott65's Avatar
Scott65 Scott65 is offline
I can't see that well... And the condition of those plugs I'd never trust to verify heat range... BUT if the line I think you're referring to was accurate, then I'd say the heat range looks very close... To the OP if you want colder try Autolite 3923, or if you want NGK, BKR6E.
Old 07-16-2021, 03:27 PM
gtorich gtorich is offline
Does your oil have a fuel smell to it?
It does not take many miles of a running rich condition to wash out the rings and cylinders, and before you know it your burning more oil then you should.
Steve, dont notice any fuel smell, my sniffer must be shot...........couple better pics for you i hope.
Also a list of what i have done to the carbs, im not that far off of a stock 389.......hope to get the a/f gauge installed soon, problem with that it works off the cig lighter, of course mine doesnt seem to work.
Wondering if it would pay to get one of those bore scopes and see if a have a broken oil ring or something that i could see.
You can see on the one pic, plugs 4-6-8 had oil even on the porcelain part, some got wiped off with me touching them.
Rich
Name:	Spark plugs 7-16-21 (1).JPG
ID:	569905   Click image for larger version
Name:	Spark plugs 7-16-21 (3).JPG
ID:	569906   Click image for larger version
Name:	Spark plugs 7-16-21 (5).JPG
ID:	569907   Click image for larger version
Name:	Spark plugs 7-16-21 (2).JPG
ID:	569908   Click image for larger version
Name:	Tripower stats on the car.jpg
Old 07-16-2021, 03:29 PM
Sorry about that upside pic..............no idea why that happened.
Rich
Old 07-16-2021, 07:05 PM
Default Oil?
IMO: The black looks like combustion residue that squeezed past threads and gaskets on the plugs. Have seen it leak between the porcelain and nut on defect or damaged plugs.
Clay
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post:
Old 07-16-2021, 07:33 PM
You do not have the needed level of vacuum to keep the power valve in the center carb closed all the way as compared to a stock 389, it’s not just a matter of the jet size as the motor does not idle on the jets.
I bet if you run your finger around the lip of one of your tail pipes it’s black , oily and smells like both gas and oil.
Old 07-16-2021, 07:43 PM
Formulabruce's Avatar
EXACTLY !!
Old 07-16-2021, 07:59 PM
1968GTO421's Avatar
Originally Posted by leeklm View Post
"been told im running too rich, right now and i dont have the number in front of me but im only a hair bigger on the jets than a 389., hard to believe im running too rich."
Keep in mind that the KRE heads will burn fuel more efficiently than old iron heads, and may need less fuel. I went from iron heads to KRE heads and new cam, added ~75hp to the engine, and required no changes to the qjet at the time.
Try some leaner jets and see how the engine acts.
Getting your A/F gauge installed will help
Sent from my SM-G965U using Tapatalk
Good advice ^. Despite popular notions, when you go up in cubic inches you do not need to enrichen the carb(s) if they were correct to begin with. Sometimes you may need to go up in CFM's but not always
GTOAA--https://www.gtoaa.org/
Old 07-16-2021, 08:38 PM
Thanks Steve............your right about the tail pipes being black, doesnt seem oily, more like a power...........seems i cant smell anything right..........i"ll ask my wife to take a wiff. lol
Cant remember about the power valve deal, but i did install the Jon Hardgrove springs that he sold to keep the power valve closed.
Im glad you guys are helping out..............this is getting more and more confusing. lol
Im gonna run these 3924 for a few miles, then try some 3923 which i have used in the past and see what comes up.
Today for an experiment i took the car up to about 5700 rpm in 1st gear, ran great, but could see some blue smoke in the mirror.............im hoping that was the tires.
Rich
Old 07-16-2021, 08:44 PM
Clay
Thanks Clay...........besides my usual issues, this is the first time i seen this oil on the porcelain and nut............i dont use much anti-seize, but when you touch the oil, almost feels like a paste.
I have a set of new plugs in now...........although that doesnt mean too much anyways.
Gonna run them for about 300-500 miles and take a look
Rich
Old 07-17-2021, 10:35 AM
cdrookie cdrookie is offline
I'm not saying it's your issue, but here's what happened to me.
I had my new Edelbrock heads shipped directly to someone to port and assemble them. I got them in 2002. I can't remember exactly when but within a year or 2 (or 3) I had the engine running. It sounded good and the plugs were a tan color. Fast forward a number of years and I moved and now have the car in my garage. I got it together enough to test drive and it never ran right. There was always 2-3 fouled plugs. I spent so much money on plugs, different brands, heat ranges, tried different gaps, I rebuilt the engine, swapped cams, different ignition system, carb, jets, PV's, but always the same results. Finally on my last cam change I got new springs to match. When removing the old springs, I saw the builder had the white umbrella seals on there, they were rock hard. Once the engine was back together with new seals....BAM! I was able to start tuning and stuff started to do what you think it would do. In the end I went with a hotter(maybe too hot) NGK plug and I had no more fouled plugs, and it was a whole different car.
I was in denial thinking that the problem wasn't the heads, since they were new. But, just like us, stuff goes bad as it gets older.
Old 07-17-2021, 03:46 PM
Thanks cd, im gonna check with Dave at SD on what seals are in there, pretty sure they are the vinton ones, but i"ll double check.
Steve 25, dont leave me hanging. lol..............any thoughts of the different pv springs i was using from Joh Hargrove ............today i cleaned the tail pipes out .........seemed like a black power than any oil..........had two people sniff my dip stick, no body could smell any gas..........so not sure whats up with that. Seems no body wants to do this, one guy took 3 beers before he would. lol.
Gonna double check with Dick Boneski on the pv spring, he only lives a few miles from me.
Rich
Old 07-17-2021, 04:25 PM
One thing in terms of checking the power piston spring out is to note how extra fuel come out of the two boosters when the motor is up to Around 4500 rpm out of gear.
You do not want to see fuel dribbling out of the boosters at idle which would indicate that you still need a lighter tension power piston spring.
How much valve lift are you running and in that same vein do you know what those heads have for retainer to seal clearance?
Old 07-17-2021, 08:32 PM
Steve...........from my records Int....627....Ext .632..........cannot find anything about retainer to seal clearance.
Never tried 4500 rpm out of gear.........will give it a shot
only other info is the sheet from SD in 2010..........hope its not upside down, not sure why my pics are comming up that way.
Rich
Name:	SD scan today.jpg
Old 07-18-2021, 03:32 PM
mchell's Avatar
mchell mchell is offline
Sounds like the gasket on the plug is not sealing if you’re getting a little oil in the hole…..provided it’s not coming from a leaky valve cover gasket etc..
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 07-18-2021, 05:21 PM
Thanks mchell.........i was thinking that also, but no evidence of the vc leaking, and i put in all the plugs the same.......1-3-5-7 no leaks, problem was 4-6-8.
I usually go hand tight, then about another 1/2 turn on the plugs............with these aluminum heads im parnoid of stripping them out.
Rich
Old 07-18-2021, 07:54 PM
mchell's Avatar
Rich
I’ve had it happen on occasion…. We tend to be a little light on the torque when seating the plugs in fear of stripping. Plus, some plugs just don’t seem to go in really nice almost feel tight. Also, the tight fit of the socket in the hole can cause a feeling that the plug it seated but it’s not.
