I can't see that well... And the condition of those plugs I'd never trust to verify heat range... BUT if the line I think you're referring to was accurate, then I'd say the heat range looks very close... To the OP if you want colder try Autolite 3923, or if you want NGK, BKR6E.
Also a list of what i have done to the carbs, im not that far off of a stock 389.......hope to get the a/f gauge installed soon, problem with that it works off the cig lighter, of course mine doesnt seem to work. Wondering if it would pay to get one of those bore scopes and see if a have a broken oil ring or something that i could see. You can see on the one pic, plugs 4-6-8 had oil even on the porcelain part, some got wiped off with me touching them. Rich |
Sorry about that upside pic..............no idea why that happened.
Rich |
Oil?
IMO: The black looks like combustion residue that squeezed past threads and gaskets on the plugs. Have seen it leak between the porcelain and nut on defect or damaged plugs.
Clay |
The Following User Says Thank You to "QUICK-SILVER" For This Useful Post: | ||
You do not have the needed level of vacuum to keep the power valve in the center carb closed all the way as compared to a stock 389, it’s not just a matter of the jet size as the motor does not idle on the jets.
I bet if you run your finger around the lip of one of your tail pipes it’s black , oily and smells like both gas and oil.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Cant remember about the power valve deal, but i did install the Jon Hardgrove springs that he sold to keep the power valve closed. Im glad you guys are helping out..............this is getting more and more confusing. lol Im gonna run these 3924 for a few miles, then try some 3923 which i have used in the past and see what comes up. Today for an experiment i took the car up to about 5700 rpm in 1st gear, ran great, but could see some blue smoke in the mirror.............im hoping that was the tires. Rich |
I have a set of new plugs in now...........although that doesnt mean too much anyways. Gonna run them for about 300-500 miles and take a look Rich |
I'm not saying it's your issue, but here's what happened to me.
I had my new Edelbrock heads shipped directly to someone to port and assemble them. I got them in 2002. I can't remember exactly when but within a year or 2 (or 3) I had the engine running. It sounded good and the plugs were a tan color. Fast forward a number of years and I moved and now have the car in my garage. I got it together enough to test drive and it never ran right. There was always 2-3 fouled plugs. I spent so much money on plugs, different brands, heat ranges, tried different gaps, I rebuilt the engine, swapped cams, different ignition system, carb, jets, PV's, but always the same results. Finally on my last cam change I got new springs to match. When removing the old springs, I saw the builder had the white umbrella seals on there, they were rock hard. Once the engine was back together with new seals....BAM! I was able to start tuning and stuff started to do what you think it would do. In the end I went with a hotter(maybe too hot) NGK plug and I had no more fouled plugs, and it was a whole different car. I was in denial thinking that the problem wasn't the heads, since they were new. But, just like us, stuff goes bad as it gets older. |
Thanks cd, im gonna check with Dave at SD on what seals are in there, pretty sure they are the vinton ones, but i"ll double check.
Steve 25, dont leave me hanging. lol..............any thoughts of the different pv springs i was using from Joh Hargrove ............today i cleaned the tail pipes out .........seemed like a black power than any oil..........had two people sniff my dip stick, no body could smell any gas..........so not sure whats up with that. Seems no body wants to do this, one guy took 3 beers before he would. lol. Gonna double check with Dick Boneski on the pv spring, he only lives a few miles from me. Rich |
One thing in terms of checking the power piston spring out is to note how extra fuel come out of the two boosters when the motor is up to Around 4500 rpm out of gear.
You do not want to see fuel dribbling out of the boosters at idle which would indicate that you still need a lighter tension power piston spring. How much valve lift are you running and in that same vein do you know what those heads have for retainer to seal clearance?
Never tried 4500 rpm out of gear.........will give it a shot only other info is the sheet from SD in 2010..........hope its not upside down, not sure why my pics are comming up that way. Rich |
Sounds like the gasket on the plug is not sealing if you’re getting a little oil in the hole…..provided it’s not coming from a leaky valve cover gasket etc..
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
Thanks mchell.........i was thinking that also, but no evidence of the vc leaking, and i put in all the plugs the same.......1-3-5-7 no leaks, problem was 4-6-8.
I usually go hand tight, then about another 1/2 turn on the plugs............with these aluminum heads im parnoid of stripping them out. Rich |
