Old 08-05-2021, 09:04 AM
ponchorob ponchorob is offline
Default lookin for 428 block
im lookin for a standard 428 block to bore my own 428 4 bolt was cracked so i need a new one ...would appreciate any help for finding one.. thanks robert
Old 08-05-2021, 09:54 AM
AG's Avatar
AG AG is offline
I have a 1967 4 bolt 428 YH block std bore in NH with the std/std armasteel crankshaft.
Old 08-05-2021, 11:25 AM
Why don't you grind or drill out the ends of the crack and have that cylinder sleeved, as that would be cheaper than buying a block?
Old 08-05-2021, 12:38 PM
sdbob sdbob is offline
I've been running one sleeve in a SD block,+.030. Block has over 200 runs in stock configuration though.
Old 08-08-2021, 05:06 PM
Default Just Asking
ponchorob,
Will your pistons work in a standard bore 455? Might give you more options to choose from in your search.
Do you have connections in the US to inspect and arrange shipping?
Clay
