Old 07-04-2017, 11:37 AM
duke455's Avatar
duke455 duke455 is offline
Default ram air manifolds
ok got a set of ram air restoration manifolds for a sec gen bird.
they came with regular header gaskets instead of the original style
so should i use the header gaskets or go get some original gaskets.
thanks
Old 07-04-2017, 02:47 PM
duke455's Avatar
Default manifolds
no advice on this ?
Old 07-04-2017, 07:10 PM
grandam1979 grandam1979 is offline
I have used both they both do well. Right now I'm using header gaskets trimmed so you can't see them.
Old 07-04-2017, 07:33 PM
FrankieT/A's Avatar
I use header gaskets as well. No issues...
Old 07-05-2017, 01:09 AM
Old Man Taylor's Avatar
I used the factory type steel shim gaskets. I never had any problems with them.
Old 07-05-2017, 07:06 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
This and little high temp silicone. The critical thing is the surfaces have to be flat no matter what you use.
Old 07-05-2017, 02:23 PM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
I used header gaskets for a short time with no issues and then I had my engine rebuilt and my builder put the original metal gaskets on and have had no problems in nine years and 20k+ miles.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 07-05-2017, 02:47 PM
IMHO, it's hard to beat using the factory implementation.
Old 07-06-2017, 11:59 PM
Formulajones's Avatar
I use copper.
Old 07-08-2017, 09:31 AM
77 Canamman's Avatar
Steel is all that is needed.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 07-13-2017, 11:17 AM
CanAmT/AGTO CanAmT/AGTO is offline
I have used steel Felpro never any problems!
I Bleed Arrowhead Red,
64 GTO 389 Tri Power 4spd Nocturne Blue Poly
70 GTO 400 4spd Palladium Silver
70 GP 400/4 spd triple Black
71 T/A 455 4spd Cameo White
01 T/A Bright Red 4L60E Ram Air WS6
02 TA Navy Blue Metalic 6 spd Ram Air WS6
Old 07-13-2017, 11:46 AM
unruhjonny's Avatar
I have almost always used OEM steel gaskets.
IIRC I did try header gaskets once, but after a short while they blew out (probably because '70 RA manifolds only use three bolts to hold the manifold to the head.
1970 Formula 400
Old 07-29-2017, 10:47 AM
grivera's Avatar
grivera grivera is offline
Can the steel gaskets be used when putting the iron manifolds on aluminum heads?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
