View Poll Results: What would you use on a all stock car that is rarely driven?
Points 25 39.06%
Pertronix 18 28.13%
HEI 21 32.81%
Voters: 64. You may not vote on this poll
Old 09-30-2017, 09:04 AM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Yes, I have the Flame Thower II with the Ignitor II. I opened another ticket with them last night since they never responded to my first ticket. I had read that the magnets in the reluctor ring are prone to falling out. Disappointed with that and the lack of response, I had very high hopes (as most people do) for this product.
Mitch Kunath
Old 09-30-2017, 12:28 PM
ANDYA ANDYA is offline
On a restored car that is mainly stock I can't see going with anything other than a good set of points. I have two cars running Blue streak points and never have a problem. I have had the same set of points in one car for 20 yrs and in another for 12 yrs. I maybe put 1000 miles combined on both cars a year. Every spring I adjust the dwell once and I'm good to go. Actually I don't mind it as it's part of the fun of tinkering with old cars. Recently I removed the cap off the distributor of the car that has the 12 yr old points just to take a look. They were shiny like a brand new penny as if I installed them yesterday. As a kid I had lots of daily driver cars that used points and also never had a problem. For me points have been dead reliable.
Old 09-30-2017, 02:14 PM
74 SD455 Formula 74 SD455 Formula is offline
I have a 72 455HO GTO. I am runnung an HEI for the reliability cause I drive my car alot,but I have my original Unitized Distributor in a box for the next owner to decide what he wants to do.
Old 10-02-2017, 09:35 PM
Kurt L71S's Avatar
Kurt L71S Kurt L71S is offline
I emailed Lectric Limited regarding your questions on the In dash tach...
Here is my question to them and then below is Dan's reply...
You have recieved a new submission from Lectric Limited.
The customer's reason for inquiry:
________________________________________
Comments / Non-technical Questions
Name: Kurt O Keller
Email: kkeller73@embarqmail.com
Comments:
BREAKERLESS-SE ELECTRONIC IGNITION CONVERSION Part #: 38131 I have two of these wonderful kits. 1 for my 1968 Camaro and the other for my 1971 LeMans Sport 350. My question is: will this conversion work with a factory installed in dash tachometer on a 1970-1972 LeMans/GTO? Thanks so much for always being at my rescue. I am forever praising this product to everyone I talk with.... Regards....Kurt
Hi Kurt,
Yes it will work fine.
Glad to hear that you have had good experiences with our product
Word of mouth is always a nice.
Thanks and have a great day.
Dan
Kurt L71S....1971 LeMans Sport Coupe 350/TH350
Old 10-06-2017, 08:32 PM
yak's Avatar
yak yak is offline
pertronix but make sure you wire it properly. it needs full battery voltage
"he has more bolt offs than bolt ons"
Old 06-01-2021, 08:28 AM
98 SNAKE EATER 98 SNAKE EATER is offline
Question
Name: Kurt O Keller
Comments:
Hi Kurt,
Dan
Can anyone here confirm this?
I've been on the fence about ordering a Pertronix ignitor due to the tach issue and this is the first time seeing the LL kits
Old 06-01-2021, 09:22 AM
Stumbled upon this site
http://www.breakerless.com/
Is this basically the same thing as the LectricLimited setup?
Old 06-01-2021, 10:05 AM
padgett's Avatar
padgett padgett is offline
I used to take a Vega (transistorized) tach circuit board (round ceramic) and install in hood tachs. Just needed quick calibration.
Web Site
Old 06-01-2021, 02:06 PM
unruhjonny's Avatar
I used to like the idea of an HEI or electronic conversion;
I really liked the idea of a built in rev limiter function that some of them offered.
Then one day I was left stranded with a a 1973 Firebird which was running an HEI;
The magnetic pickup went bad.
That was my introduction to the down side of low maintenance electronics.
I am now absolutely a proponent of sticking with points if it's a points car - if points go bad, you can swap them out in a couple minutes with a screw driver.
1970 Formula 400
Old 06-01-2021, 02:57 PM
padgett's Avatar
I've been running GM electronic ignitions for many years (back to Delcotronic days - had one in my 63 FI split window). Have always been impressed by how reliable they are. In fact through today have had more coil failures (and one cap punch through) than anything else. Carried a HEI module in the glove for years and never needed it.
Had a Pertronix in my 66 Monza 'vert until sold. Have one for my Judge just never hooked up (RSN). Key is to have the right coil for the module.
Web Site
Old 06-02-2021, 02:46 AM
Kenth's Avatar
Kenth Kenth is offline
I´m a fan of using the ignition system on the car from factory.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 06-04-2021, 07:04 PM
bird72's Avatar
bird72 bird72 is offline
As an HEI note, I have had NAPA premium modules last a year or two with only a couple hundred miles on them. I went thru 3 of them over a few years. Either I have a gremlin in the mix, or the modules are junk. I put in an Accell one a month ago, we'll see.
Old 06-07-2021, 11:38 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
I did this very thing last summer when driving my 72 LeMans GT back to AZ from MO. Sure was a simple, quick fix and back on the road.
However, I do like the HEI's as well, but as mentioned, they can leave you stranded. I run both setups in my fleet for various reasons. Pro's and Con's all around.
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Thread Tools
Display Modes
