69 Firebird 400 4BBL accelerator linkage issues...no WOT for me!
In an update to my previous thread, a local Pontiac club member got my carb almost sorted out.
Electric Choke set too rich, reset that, now it fires up the first time with one pump of the pedal. Adjusted the secondaries linkage on the Q-Jet, they now open easier. The kick down switch and the accelerator cable and pedal are now the limiting factors. It looks like the linkage hold down bracket was modified when the HEI dizzy was installed (removed the coil holder). Bad news is that now the cable is still about 1/2" less travel to open the secondaries properly. At this point, looks like it's either the wrong cable in there, or the accelerator pedal isn't pulling the cable far enough. Doing a visual with the gas pedal floored, it's barely tripping the kick down switch, and it leaves the secondaries open just slightly, nowhere near vertical for WOT. Has anyone else had to deal with this? And if you did, how did you resolve it? Thanks for any tips! JIm |
fairly sure both the cable and bracket are different between 2 bbl and 4bbl
on my a bodys they are almost an inch diff |
Considering the Q-Jet should have a longer pull to open the secondaries, that seems logical. When the pedal is floored it barely gets the rubber accordian grommet for the kick down switch wrinkled. But if you push on it manually it goes a lot farther, like another 3/4" or so.
Time to consider bending the pedal under the dash to see if the rod is getting full travel on the cable, I'm guessing? |
I have the same problem with my 68 FB. I changed from a 2 BBL to a 4 BBL Holley & RPM intake. I can push the pedal against the floor, then grab the cable end and pull it out about 1/2" more (which results in full carb stroke). I tried adjusting/changing the bracket on the intake with no effect. I could not see how bracket position or length of cable would affect stroke distance. I plan on bending the pedal curved arm to make up the distance. That would also result in the pedal being higher off the floor when at rest. I also researched the pedal assembly and it is the same for 2 or 4 BBL.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
Check your cable travel before going after the pedal. I may be wrong, but I think the cable may have a "stop" that will limit the amount of movement you can get out of it.
As Scott says, I had to get a longer cable when changing from 2bbl to Qjet on my LeMans. He even sold it to me IIRC! |
Well, the car/engine is matching numbers, and the carb # matches for the correct carb #, too. But as I got this as a "mostly completed" amateur restoration in October 2015, I can imagine there are probably some variables in what was done to it, and maybe the cable or gas pedal are one of them.
As it is now, the accelerator pedal is about even with the power brake pedal in height. So that makes me wonder if all the adjustment is taken there and now it's a cable or cable clamp issue. |
You mentioned "electric choke". The original 1969 Pontiac Q-jets are divorced choke, not electric.
They make an electric unit that mounts to the intake to replace the divorced choke, if that's what you are calling an electric choke set-up......Cliff
If it drives bring it to Endery tomorrow,Baker will be there along with a couple first gen guys.We get there about 7:30.Tom
It is possible to add a shim behind the cable to help achieve WOT. If you don't want to bend stuff or look for different parts.
'65 Tempest 467 3650# 11.30@120.31 |
Bending the pedal could help some too. |
I would but we have a 10:00 am meeting we have to drive to so there's not enough time to go there, drive back to Whittier and back to our 10:00 appt.
It seems the gas pedal and/or pedal to carb cable is the problem now. |
We leave there at 9!EZ drive to whittier on sunday AM.Tom
Yep, I get it. It's the next place to go, the wife has to shower, makeup, dress, yada yada yada. Can't do it all in the limited time since the next 10:00 meeting is 40 miles from Whittier.
You'ed be surprised how much the secondary's on a Carb can be closed down and not effect the power much at all!
Thanks for that tip, Scott65!
Something isn't right, and I'm sure it's simple enough to fix, but right now it's pretty slow. I took our 99 Ford Explorer Sport (V6) out and it's faster than the 69. Considering it's got two less cylinders and about 2000 lbs more weight, that was demoralizing, to say the least. |
I had the same problem with my 69 GTO many years ago. After a while the gas pedal linkage starts to bend from flooring it a lot. I bent it back up and the problem was solved for a few months and then it slowly bent again giving me the same problem. I had to weld a rod in to beef it up. Been holding up ever since. I will try to post a pic if I can.
http://www.machdevelopment.com/album...775/527566.htm |
Here is a pic. I couldn't get a completely clear shot but you can see the rod that's brazed in there to make a triangle. Its solid as a rock now.
