Old 01-25-2021, 01:18 PM
David Jones's Avatar
Default Measuring Q-Jet Primary Jets
I'm going through my stash of jets and doing a little measuring....where I can.
One thing I've found is that very few of the jets are actually what they are stamped. Even what appear to be new ones. Some are 3 sizes larger than the stamped number. One thing I've run into is lack of the correct numbered bits in my measured bit box. The box jumps from .073 straight to .076 and none are missing. I've got an .075 stamped jet that I think is actually .075 but I can't measure it.
Is there a work around to measuring the .074's and .075's that are actually what they are stamped?
Old 01-25-2021, 01:33 PM
steve25 steve25 is online now
Well it’s kinda the same thing with old Style Holley jets where stamped numbers could wander up or down from the stamp.
I would wait for Cliffs response to your post,
Old 01-25-2021, 01:53 PM
Cliff R's Avatar
Cliff R Cliff R is offline
Common problem, and why I toss them in the round file (trash can).
Those carbs have been out there for at least half a century at this point. Many are worn from use (metering rods sliding up and down in them) or just engine vibration. There will be a percentage that have been hand drilled to larger sizes by the owner or his well meaning beer drinking buddy or local "guru" trying to fatten things up to help make more power, etc.
I don't even look at them and haven't for many years, we just replace them.
The metering rods fair a little better than the jets as they are most likely a little harder, but they still need to be measured before reusing them. I replace those as well about 95 percent of the time, and why I've stepped up to have custom ones made. On the same subject we recently added another metering rod to the line-up, it's a full tapered "M" style rod starting at .050" and tapering down to .036", instead of being "stepped" like the factory "M" series rods.......Cliff
PS: I need to add here that currently there are 4 different jets being sold that screw right into the casting. 3 of them are incorrect as the Quadrajet metering jets were very specific for depth of the orifice and leading entrance/exit angles, etc. I get carbs sent here all the time with the WRONG ones in them....FWIW.....
The Following User Says Thank You to Cliff R For This Useful Post:
Old 01-25-2021, 04:19 PM
Kenth's Avatar
Kenth Kenth is offline
Decades ago i found that stamped number on jets does not reflect drill size.
By measuring factory new jets i found drill size of a #78 Quadrajet jet may very well measure .081", and in the other end a #66 jet measures .064".
The reason for this is that Rochester flow tested jets and then stamped the appropriate number, just like Holley, Carter and other carb manufacturers did.
As for checking a #74 jet a 1.9 mm drill bit is suited.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 01-26-2021, 07:25 PM
carbking's Avatar
carbking carbking is offline
If you need to measure the inbetween's, fractional metric drills fill in many of the gaps.
Jon.
The Following User Says Thank You to carbking For This Useful Post:
Old 01-26-2021, 07:51 PM
mchell's Avatar
mchell mchell is offline
For those oddball jets and other orifices where a drill bit doesn’t match, I’ve I used cheap 1/8 brass punch’s(or appropriate closest size) , chucked it up in my hand drill and simply filed and sanded to the size I want.... marked it and threw it in the kit
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
The Following User Says Thank You to mchell For This Useful Post:
