Hydraboost Units
Hi: Anybody purchase a Hydraboost Brake unit in the past 4 months? Wondering if any suppliers have them.
Thanks |
I've had one on order since Dec 2020. Seems the Bosch units are in short supply.
Thanks |
I need to order a Bosch unit too. With all of the ECOBOOST engines in vehicles out there the demand for the units is very high from the OEMS.
Tom V.
Ya I’ve tried two different vendors. Nothing to date.
Thanks Tom |
Did you check with Hydratech? They're probably behind as usual (I heard one of their top techs left), but they might be able to steer you to a vendor, like MCBparts, who order a bunch at a time...the units are often spoken for but you might get lucky.
"If the best Mustang is the Camaro, the best Camaro is actually the Firebird" David Zenlea |
Have one on order from Hydratech for 4 months. Thanks for the info. Will checkout
Thanks |
Maybe source one from a salvage yard? They're incredibly common in Astro vans.
I put one in my 70 lemans from a Avalanche and it was pretty easy. The firewall mount I purchased off the internet,
cut the input from the brake pedal and the head off of a fine thread bolt and welded it to the shaft and used the end off the original booster and it went very easy. I also added a return to my power steering pump instead of a "T". I would do the same again. I taped off and painted the unit and ALMOST looks factory. I added a power steering cooler just in case different opinions on many for this upgrade it works extremely well. |
Not sure if you checked your local Advance/Autozone and also just found a bunch on Amazon.....
Thanks for the info guys. My unit from Hydratech is pretty much on it's way end of week. Like I said these unit are in short supply. MCB has a show unit on the shelf as of today not spoken for. Thanks for the contact Gator67. I did see some on Ebay also. Thanks DOC.
Thanks, I've looked at a few online that are rebuilt, but shied away from a rebuilt. I've also heard that the Astro van ones are the units to use. Thanks again.
Nice job Paul. Thanks for taking the time to post. I'm gonna look into these units from Chevy Vans down the road. I did the same as you. I added a return line to the pump. I also added a cooler. I already have a Hydraboost unit in my 76 T/A and they work incredibly well. |
Buddy of mine has one on his '75 T/A with a 455 Butler Pontiac in it. He says "that sumb!tch stops so hard it'll throw you through the windshield if you're not strapped in".
Lol, Yes the one on my T/A is right up there with the best upgrades to the car along with the TKO-600 and the Hydraulic clutch.. It will definitely stop the vehicle. Thanks Brian.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
Years ago, I bought mine from http://www.custompowerbrake.com/
Pedal feel and brake (4 wheel disc) operation are as good as any modern car I’ve driven.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Thanks David. Good info on their website..
I have a HydraTech setup for sale, brand new, mocked it up once, never had fluid in it, has the upgraded lines and coatings. It's a 'Street Prep' with the gold anodized accumulator cover, and a matched disc/disc master.
I literally was about to post it on eBay.... .
Well I’m sure someone might grab it on here. I bought one already. Suppose to ship this week. Shouldn’t be hard to sell as there in short supply everywhere. Thanks
Smart, I had issues getting a hydroboost unit on my GMC square body some years ago. Had to try 3-4 different ones to get a non-leaker and then it would start leaking within 16-18 months. New is the way to go.
