GTO George |
You for got the alky. How large a radiator you run george? Size of fan? I am planning on upsizing the radiator too. Perhaps the extra capacity will require less fan and pump use.
It all works now. I just think the optimas have very little reserve capacity.
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
I have a pretty good sized radiator with 2 10" fans. Yes I run Alcohol. The yellow top Optima I have is Group size 31T it has 155 reserved minutes. I like running an alternator for its consistency in volts (very important) 13.5 or so all the way down the track pass after pass after pass.
Seriously there are a bunch of different ways you could go.............this combo has been working for me for years and years. GTO George Last edited by GTOGEORGE; 01-02-2016 at 12:33 PM. |
16v is the way to go. I had an issue with the electric fan popping the fuse. Called the manufacturer and they told me to put a bigger fuse in. I questioned it but it hasn't given me any other problems. Increase your volts you increase resistance.
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot 72 LeMans "POS" - Next US beast |
GTO George |
Mines pushing 15-1 and the 16v does better than 12v. Just saying.
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Agreed.........compression makes a differance 16 volts would help the starter. You can still run an alternator for consistency in volts. GTO George |
The 6 volt starter in my old Baja Bug cranked so fast with 12 volts that I think the engine slowed down at idle. LOL Never hurt the starter.
Throughout the 90s when I was mud dragging, I switched over to 16 volts to compensate for the voltage drop that I encountered from not running an alternator. I was running a 399 cubic inch sbc with 13:1 compression in a 1974 Chevy truck with factory wiring still in place. Typically I would make 6 passes at around 4.4 seconds per pass (150 foot track in 12-18" foot deep mud) plus staging and warm-up. By the end of my 4th pass, the throttle response would get sloppy with the 12v battery in place, but with the 16v it remained crisp throughout the day. I was running a MSD 6AL with a 2 step box, trans brake, ACD air shifter, Moroso water pump drive, large electric fan on the radiator, a Holley blue fuel pump and an electric fan on my trans cooler.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
I do run a alternator as a matter of convienance to avoid problems should we go to hot lapping. Should I get there. :-)
I'm running the XS. Still working great after 3 seasons. I've been very happy with it.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
Rick you run an alt?
FYI
I had been running 12V Optimas in my 72 Olds 442 race car for 8 seasons. Switched to XS 16V last year. Never going back to 12V. Everything is better.
Go 16 volt. Dont look back
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
No I don't run an alternator. I just throw the charger on it between rounds. It doesn't take very long to charge it. On alky it doesn't need to cool between rounds and very rarely do I have to run the fan so I don't drain it much between rounds. It will go quite a few rounds if need be without charging though.
