Has anyone manufactured a rotisserie that can handle the weight of a '69 GTO HT?
I found a Web site body rotisserie that shows use of two slightly modified engine stands as the supports. Although this design does not permit 360 degree rotation using the stand vertical riser as-is, a new riser that is long enough for the body to clear the stands should be an easy mod. I am considering using to 1,000 lb engine stands and was curious if anyone out there has made such a rotisserie successfully.
1969 GTO Restoration |
Al,
May I suggest doing a search on the subject, I found this http://performanceyears.com/ubb/ulti...c;f=7;t=000227 Hope this Helps ...... Al
I'm a man... but I can change... if I have to... I guess.......(Red Green) |
