Old 11-07-2022, 08:00 AM
dv657172 dv657172 is online now
Default Date Code question
What does the letter "K" represent on a starter? Oct or November (i.e. was "I" skipped in the sequence)
Also is the answer the same for block, head and exhaust manifold casting dates?
Old 11-07-2022, 08:10 AM
johnta1 johnta1 is online now
On stamped codes, the 'K' is October. ('I' is not used)
On cast in codes (like block, heads) 'K' is November. ('I' is used)
Old 11-07-2022, 08:19 AM
Thanks Johntal!
Old 11-07-2022, 08:30 AM
One more question on an assembly date....
My 72 GTO has an assembly date of 11C which means third week of November, 1971. Is that the Sunday through Saturday (14th -20th) or 15th day - 21 st day?
I know some dont care about these details but I enjoy all the documentation stuff.
Old 11-07-2022, 08:36 AM
turbo69bird's Avatar
I could be wrong but I isn’t always skipped it was only certain years I have seen casting dates with an I in them
Here’s an example
https://forums.maxperformanceinc.com...84#post6150584
The pic I chose may be incorrect may just be a obliterated by the plug but the thread w the manifold describes it and I’ve seen others post about an I being used for date coded parts on certain years
960 HP @ 11 psi, 9.70 at 146.
The Following User Says Thank You to turbo69bird For This Useful Post:
Old 11-07-2022, 10:32 AM
I just saw a lengthy post about the I being skipped or not a few days ago maybe in a RAI RAII conversation . And I can’t find it searching now . I is used so much for other things it makes searching it hard. But the basic jist was that it is used in some instances. Wish I could find it for you guys.
Old 11-07-2022, 02:48 PM
Kenth's Avatar
Kenth Kenth is offline
11C on Body Plate is when body was finished at Fisher Body, not necessary the date when car was fully assembled.
You will find the finsished car assembly date on the build sheet, which could be weeks later.
HTH
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-07-2022, 06:20 PM
Hmm...Always thought that was the assembly date time. Interesting.
If actual final assembly date is in box #10 on build sheet then it was Nov 16 which still falls during the week 11C
Old 11-07-2022, 08:03 PM
Keith Seymore's Avatar
My 72 GTO has an assembly date of 11C which means third week of November, 1971. Is that the Sunday through Saturday (14th -20th) or 15th day - 21 st day?.
I don't think we can shoot that straight. There's a lot of margin around these various dates.
I was there when my truck was built and the documentation is off by a day.
K
'63 LeMans Convertible
'63 Grand Prix
Old 11-07-2022, 08:43 PM
That pic is of a CAST date code, which would have an 'I' for a month.
There was however one year (1967?) that they had a 'M' (for December?).
May be the thread you are thinking of.
Something about overlapping of model years? (start of 1968 model in 1967, but still building 1967 model year? Like 1st year of Firebird?)
Old 11-07-2022, 09:14 PM
I just had someone else tell me it was one year and it was 66 so not sure when it was but I did see some posts surrounding 67 68 ram air cars so it’s around that time for sure . Of course a 67 model year car could have had a 66 cast date so not sure.
