70' coil spring, help needed
Hi there,
I'm seeking some advice, I will need to buy front & rear coils for my 70 GTO which I'm restoring. body is presently off at the frame, I will replace the body bushings as well. Looking to have a correct stance once done, I want the car to be within the stock ride height. I don't want to end up with 'off road' look. The coils that I had on the car were incorrect. Any suggestion would be appreciated. 400, Auto, PS, PB, non-A/C. |
Not sure if it makes sense for you so just 2 cents. On my second gen Firebird I only have coils on the front. After all the pains of height configuration on the front over the decades, I went to coil-overs. Problem solved for me and I am extremely happy with the flexibility. Wish I had coils on the back, but I am staying OEM style so have figured my way around that. The front flexibility made that aspect easier to work with.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Front Coils Moog 5390 https://www.ebay.com/itm/39410496498...Bk9SR-biydeRYQ
Rear Coils Moog 6319 https://www.ebay.com/itm/33454256663...Bk9SR-Lw9deRYQ |
For my 72 I bought from Ames and they look stock like I wanted.
TJS do you have picture of your 72? I need new rear springs for my 72.
A new best of 9.135 @ 145.41 71 Lemans Sport. 72 Lemans Sport. |
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
Here ya go. Keep in mind, I also put one inch spacers on top, as some say a vert sags when top is lowered. I am glad I did.
