Old 03-17-2021, 07:54 PM
69Goat1's Avatar
69Goat1 69Goat1 is offline
Default Dyno day is almost here!
Been a long time coming! Way back in April of 2013 I broke my old stock block 462 in half on the street near my home.
It was a block failure...split from main up through the cam tunnel. This old engine with a set of 64cc Eheads was powering my 3600 lb GTO to 9.8’s in the quarter. I swore I would never build another engine for it unless it was an aftermarket block.
In the meantime my wife and I found 80 acres of land we wanted so I stored the GTO and we purchased the land and I fenced it which pretty much took our extra money for closing and fencing. A year later we had some more savings and decided we wanted to live on our land because we loved it so much so we built a house and shop on it. Again no extra funds...I saved a couple bucks and bought an IAIIA block in 2017, about a year later I bought a set of heads, 2 intakes, shaft rockers, lifters...
In 2019 I took the GTO to a chassis shop that mini tubbed it, rack and pinion steering, control arms, brakes, coil overs, crossmembers, tube core support, and a lot more roll cage.
2020 I decided it was time to start putting things together. I also decided the end result would be Mechanical Alcohol injected 535 CI so I needed an intake and sent a Gutsram I got with my wide ports to Hampton Blowers to get a top put on it...
We bought a cam based on 12.5-1 Blown alcohol.
Here is what it looks like with the 8-71 and hat...
But we are dynoing it built like this on gas and I will add the alcohol injected supercharger later...
What do you think this 380 CFM wide ported, 12.5:1, 535 ci engine should make on gas with the cam listed on the cam card with a 1050 dominator, Victor intake? We are dynoing Friday...
Sent from my iPad using Tapatalk
1969 GTO, 3370 lbs, 10.5” tire...
07/31/21 Norwalk 9.42 @ 142 1/4, 5.95 @ 115 1/8th mile 3400 lbs...535 with Junk dinosaur Eheads
Old 03-17-2021, 08:06 PM
shaker455's Avatar
shaker455 shaker455 is offline
Congrats!
It's been a long time coming for you!
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 03-17-2021, 08:10 PM
Scott Roberts Scott Roberts is offline
First and foremost, im glad to see you're going injection and not carbs!!
That lobe separation looks a bit tight for a blower car in my opinion..
Last, im most impressed with what you did to your block! Thats a true racer right there..
Old 03-17-2021, 08:17 PM
69Goat1's Avatar
Originally Posted by shaker455 View Post
Congrats!
Yes it has!!!
Old 03-17-2021, 08:25 PM
69Goat1's Avatar
Yes, the power potential with injection over carbs is too impressive to not try to take advantage of it.
I thought the same thing on LS of the cam but that is what my engine builder got as a recommendation from Comp...I figured it should have been at least 114.
That blown up engine lasted a long time. I changed the oil in it and found a main cap dowel pin on the magnetic drain plug. I pulled the engine and found where it came from and pulled the cap and reinstalled it. Nothing looked out of place so I buttoned it up and I decided to take it for a rip down the Highway...it got just into high gear when it let go...even more impressive is it lunched the converter, broke the trans bellhousing, and took out the ring gear in the rear!
Old 03-17-2021, 09:04 PM
slowbird's Avatar
slowbird slowbird is offline
Nice!
Who did the wide ports (they look cnc'd)? What valves are in them?
The Following User Says Thank You to slowbird For This Useful Post:
Old 03-17-2021, 09:06 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Glad to hear its almost done. 👍
The Following User Says Thank You to Scott Stoneburg For This Useful Post:
Old 03-17-2021, 09:17 PM
scott70's Avatar
scott70 scott70 is offline
725HP?
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
The Following User Says Thank You to scott70 For This Useful Post:
Old 03-17-2021, 09:38 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Looks great! Well worth the wait.
Go fast, see Elvis!
Old 03-17-2021, 10:39 PM
77 TRASHCAN's Avatar
Where are you getting it dyno’d at?
Shut it off
Shut it off
Old 03-17-2021, 11:03 PM
Dragncar Dragncar is online now
You are going to have a great time with the new engine,congratulations. Engine looks bad to the bone, mean.
That engine blown must have been quite the experience.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 03-18-2021, 12:27 AM
Stan Weiss's Avatar
825 HP
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 03-18-2021, 07:10 AM
charlie66's Avatar
When the engine let go , did it look like that in the car or did it fall apart while lifting it out? Thats scary..
My Half AN Injun.....
Old 03-18-2021, 08:13 AM
Engine looking good with the blower!
781 HP (Naturally Aspirated)
Old 03-18-2021, 09:39 AM
grandville455's Avatar
grandville455 grandville455 is offline
810 HP NA
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
The Following User Says Thank You to grandville455 For This Useful Post:
Old 03-18-2021, 11:57 AM
69Goat1's Avatar
Originally Posted by slowbird View Post
Nice!
They are hand ported. I have no idea who did them originally originally. I had them flowed and that was it other than having 2.19 titanium intake and 1.77 stainless exhaust.
Old 03-18-2021, 12:00 PM
69Goat1's Avatar
Originally Posted by scott70 View Post
725HP?
I hope a little more. My blown up stock block 462 way back in early 2000’s made 716 with standard port e heads. You may be right though but I would be very disappointed.
Old 03-18-2021, 12:01 PM
69Goat1's Avatar
Shinook
Old 03-18-2021, 12:04 PM
69Goat1's Avatar
It actually just stopped immediately and did a quick lock up of the rear and then release.
Old 03-18-2021, 12:05 PM
69Goat1's Avatar
The oil pan and intake was holding it together...
The Following User Says Thank You to 69Goat1 For This Useful Post:
