Old 09-25-2022, 10:50 AM
Shiny Shiny is offline
Did the factory put rubber strips between the straps and the tank? I see these sold but not in my repro repair manual.
I did order a pad from Patton Glade... thanks to all for the info.
Mike
Old 09-26-2022, 05:43 PM
When I removed my original tank, there were no rubbers between the strap and tank. I didn't put any back either. Just another area to retain moisture.
Old 09-27-2022, 10:55 AM
Is it possible they stopped using the pad between tank and body after 1970? I think I read that somewhere while click-shopping for a tank.
Old 09-28-2022, 06:16 AM
tigergto's Avatar
tigergto tigergto is offline
There wasn’t any padding on the top of the tank on my 71 GTO. I’m sure it was the original tank.
Old 09-28-2022, 06:40 AM
tigergto's Avatar
Old 09-28-2022, 03:05 PM
dataway's Avatar
dataway dataway is offline
I used the repop heavy rubber pad on my 68 (between tank and body) ... it made getting the straps hooked up a real pain ... that extra little thickness seemed to be all I needed to get the front strap bolts started. Like many I resorted to a floor jack and wood.
Old 11-06-2022, 05:17 PM
lamans71, Here is a 68-70 A-body tank with the factory insulation mat to give you an idea of how it was placed during assembly (Baltimore car).
Dennis
Thanks again to Dennis for posting his photos!
I am starting to install my tank and found the pad I ordered from Patton Glade is significantly larger than the original Dennis shared. I attached a photo of his pad that I downloaded from an Oldsmobile forum site.
I plan to cut my new pad closer to Dennis's photos.
Mike
Old 11-06-2022, 06:57 PM
SD455DJ SD455DJ is offline
Shiny,
Glad the pictures helped...and at least your new pad isn't too small.
Dennis
Old 11-06-2022, 10:45 PM
I had to compromise... the new tank has a bulge that I decided to cover with the pad so I cut it about full-width.
Mike
ID:	601815   Click image for larger version
Old 11-06-2022, 10:52 PM
I suspect the new tank had been dropped but the filler neck definitely needed persuasion to align it with the old tank.
Old tank:
New as-received:
After bending:
ID:	601818   Click image for larger version
ID:	601819   Click image for larger version
Old 11-07-2022, 07:45 AM
dataway's Avatar
Looks great.
I have a feeling they expect you to bend those to the right position. I bet they found that if they are pre-bent to the right place that the neck takes too much abuse during shipping.
Old 11-07-2022, 10:45 AM
Could be! So everyone gets to do this! The carton arrived FAST and in great shape (Spectra tank ordered through Autozone) but the neck was sticking out - definitely awkward. It was easy to bend but stressed the solder joint as the tank bent, not the tube. Fingers crossed.
Old 11-07-2022, 11:23 AM
Holeshot71's Avatar
Holeshot71 Holeshot71 is offline
I have a buddy that does roofing and he had some of that ice shield barrier they put down at the edge of roofs. He gave me the end of a roll that was enough for a couple of cars. Cut it to size and put it in without peeling off the film on the sticky side. Been in there for at least 15 years now with no issues.
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55
'72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80
