Old 09-10-2022, 06:36 PM
reddog65's Avatar
reddog65 reddog65 is offline
Default How do I install the stainless hood trim?
I picked up a stainless trim piece that goes on the back of the hood for my 72 GTO and want to install it.
Do you snap the piece on the rear of the hood or do you open one end and slide it on untill you get to the other side and then close the end back up?
Regards,
Steve in Arizona
Old 09-10-2022, 06:52 PM
tripower's Avatar
tripower tripower is offline
Line it up and snap it on directly, no slide.
Norm J
Old 09-11-2022, 01:19 AM
dataway's Avatar
dataway dataway is offline
Yep ... and put a bit of time into figuring out where to put it. Seems to be some variance in length ... you don't want it hanging off one end more than the other.
I used a large rubber mallet to tap it on slowly. If the hood has modern paint with numerous coats of clear it's going to be a snug fit.
Old 09-11-2022, 10:44 AM
scott70's Avatar
scott70 scott70 is offline
Bingo. Been there done that.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
The Following User Says Thank You to scott70 For This Useful Post:
Old 09-12-2022, 01:00 AM
reddog65's Avatar
Thanks for the tips. I will try putting it on (have rubber mallet if needed Ha, Ha)
Regards,
Steve in Arizona
Old 09-14-2022, 04:59 PM
I used a rag and wiped a little WD40 on the edge to help it slide a bit better.
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 10-25-2022, 11:10 PM
MJZ's Avatar
MJZ MJZ is offline
Mine snapped on with no issues. If you need to be able to adjust, spray a little hairspray to the edge your putting the trim piece on, it allows a short period of time to adjust trim.
