Old 01-22-2021, 02:17 AM
SD421's Avatar
SD421 SD421 is offline
Default Where Do These Two Plastic Trim Pieces Go?
I cannot remember where these two pieces go.
Near the windshield/headliner? Ames Catalog calls them “Front Windshield Upper Inner Lace”
Could someone post some pics please?
Thanks,
Don
ID:	559059   Click image for larger version
ID:	559060   Click image for larger version
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 01-22-2021, 07:37 AM
Jeff Hamlin's Avatar
Appear to be the bottom finish trim for the rear shelf Sail Panel "Ear Muffs"
used on the first design (Small Panel)
Old 01-22-2021, 09:02 AM
Andre's Avatar
Andre Andre is offline
I agree with Jeff's assessment. First design smaller headliner "ear muff" bottom trim. Still not sure when the switch to the larger one occurred, which I think also eliminated one of the headliner bows?
The Following User Says Thank You to Andre For This Useful Post:
Old 01-22-2021, 12:40 PM
SD421's Avatar
Thanks Jeff.
That solves my issue!
Don
1966 GTO
1966 Tri-Power
1967 670 Heads
Old 02-23-2021, 05:43 PM
geeteeohguy's Avatar
Good to see that you're working on the little fiddly bits to get the car 100% back together, Don. Every little bit helps.
Jeff
Old 03-14-2021, 12:20 PM
SD421's Avatar
Thanks Jeff. I’m currently having the headliner and seats redone .
1966 GTO
1966 Tri-Power
1967 670 Heads
