Which harnesses?
I will be converting my ‘66 GTO from standard gauges to rally gauges. Studying the wiring harnesses offered by our host, it appears I will only need dash harness M09520(V8 Column Shift AT or All MT, w/Gauges) and tach harness M11095(1966 All V 8). Is that all I need as far as harnesses go?
Terry Hunt "He'd need 5 years in the fifth grade just to get an idiot certificate" Smokey Yunick re: Bill France Jr. |
If I remember correctly there is a harness that converts standard gauge to ralley gauges by extending the needed wires for water temp, and oil pressure, and fuel. If your original harness is in good condition, this is an inexpensive option. Tach harness is always seperate except for the lights which plug into the existing dash harness.
I would call M&H and speak to Darrin to confirm.
1970 GTO (Granada Gold) - 400 / TH400 |
Agree. I put a new M&H in my car last year. Colors were exact match to original. Harness was very easy to install and looks 100% original.
Which harnesses
Yes, I will be using M&H harnesses front to rear, since my existing wiring looks suspect to me. and I’ve been very happy using their products on previous projects. Not cheap to replace everything, but I just don’t want to hassle with all the crazy electrical quirks that often come with 50 year old wires.
Thread Tools | |
Display Modes | |
