Old 07-31-2012, 06:06 PM
richmas5 richmas5 is offline
Default 1970 pontiac block question
Are all the pontiac 1970 400 block part numbers 9799914 or 9799915 regardless of horsepower rating and vehicle application
Old 07-31-2012, 07:28 PM
Yes.
Old 07-31-2012, 09:00 PM
Thanks for the info john ,I was hoping that was the case
Old 07-31-2012, 10:49 PM
russosborne's Avatar
russosborne russosborne is offline
Would the difference be whether it was for an automatic or manual? Or ???
Thanks,
Russ
Old 07-31-2012, 11:17 PM
marxjunk marxjunk is offline
914 is drilled for 4 bolt mains but 2 bolt
915...at least all ive ever seen is a 4 bolt main..there other guys that are much more qualified that will speak up
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 08-01-2012, 08:02 AM
Thanks,
Russ
No.
The stamped code would basically be the difference.
(block the same, internal parts different)
The 915 as said, would be definitely 4 bolt main caps.
The WS/YZ 914 would be 4 bolt main caps for sure.
Most of the 914 blocks were drilled for 4 bolts caps but had 2 bolt caps.
Old 08-01-2012, 07:54 PM
Thanks, filed away for future use.
Russ
