Engine won't turn over.I've got a 72 GTO I've done from ground up. I had it started before I put the body on by just rigging up some wires to the starter, my ignition and then to a battey. I then put the body on and wired up the engine, which includes a Mallery 9000 Comp. distributor and Promaster coil all with new wiring harnesses. I followed the wiring diagram on the dis. and coil, by the brown wire ground, green to neg. on coil, red to hot on coil w/another from there going to one side of the resister. On the other side of the resister I have the factory hot coil wire(which reads 12V w/key on) and a jumper wire from the factory dir. wire(The blue wire that would plug in the cap). I have tail lights but it won't turn over. Could it somting w/the neutral saftey switch? I also checked to make sure I had the starter wired up right as well as checked for 12V at alternator, all was good. So what do you think?
This world is your world, so take it, but take it easy. |
Never mind, I got it.
so what was it?
