#61
It's a shame that not many people are aware of how the RobbMC starter doesn't have an offset motor like 99% of the other "mini" starters on the market (planetary, rather than spur gears).
#62
Finally got the engine in yesterday. We had some issues with the thickness of the crank spacer that came with the Wilcap adaptor kit, but they took care of them quickly and with no extra charge.
The RARE long branch headers fit past the steering with plenty of room. With the engine in, I've got a long list of things I can do to stay busy for a long time. Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
#63
Looks good! I like that you painted the aluminum heads to match the block.
#64
I spent some time the last few days modifying the stock '60 trans crossmember to accept the TH400. Since I used the '60 block and a 3/4" thick adaptor kit, I had to notch the front of the X-member to clear the trans pan. Since I am hanging the trans off the back, I decided to box the X-member completely with 1/8" steel plate and then I built the "porch" off the back with some leftover 1/8"steel pieces from my race car chassis build. After taking the last picture, I drilled the holes for the polyurethane mount and installed it. Works---didn't deflect at all when I lowered the tail end of the trans down on it.
Next up, driveshaft shortening. I'll have the driveshaft shop do it and replace the U-joints while they're at it. The driveshaft yoke fits right into the TH400 and should work fine. It looks like I'll need the front driveshaft shortened about 2", depending on how much of the yoke they recommend leaving sticking out of the TH400. The factory manual said 9/16" for the original Hydramatic. Jim |
#65
The project is coming along real nice Jim. Sorry we were not able to visit and see it yesterday. Everything looks to be fitting and working well. Cannot wait to see it on the road!
Hundreds of Pontiacs in Az "Real Pontiacs only..no corporate nonsense!" Facebook- Pontiac Heaven Hosting- 23rd annual Pontiac Heaven weekend- Phoenix pending due to covid Pontiac Heaven Museum in process Phil 2:11 |
#66
Jim
#67
Don't think that X-member will flex anytime soon Jim..
I used a late model trans mount with single stud mounting at X-member.......Had to use 1" - 1&1/4" spacers to elevate trans to center driveshaft in tunnel..don't know if it was because of non 60 mount ??? I got to modify my X-member for dump tube clearance some time or other.. Your truckin' man... Did you see the "Modern Custom" in latest Smoke Signals? I thought it looked pretty slick..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
#68
After I get the driveshaft to the shop and back, I'll align it all according to the shop manual. When I did a preliminary check, it didn't look too far off. I don't get "Smokes" anymore. What did I miss? Installed the RobbMC fuel pump today and replaced all the short factory rubber fuel line connectors with new rubber hose. Getting rid of all those wire factory fuel line clamps. I never could get those to work with my pliers. I suppose there's some tool (J-481QL14?) that makes removing those clamps easy. I just never owned it. One nice thing about a custom: no need to worry about how the factory did it. I've done restorations before--just don't have the patience anymore. Jim
#69
Here ya go Jim...
There was shot of your Tempest too...
#70
Thanks. Now I'll have two reasons to see a copy. I didn't know my Tempest was in it.
Jim |
#71
Something different. Will have to check out my mates copy when he gets it.
57 Superchief IAII CV-1 Heads, Megasquirt EFI, S480 turbo |
#72
Had the pleasure of meeting Steve at Norwalk...
#73
Met the Butlers, Arnie Beswick, saw some great Pontiac racing and fell in love with a '63 Tempest that was running there. That planted the seed for my racecar build years later. Jim |
#74
Jim, What brake set up did youi go with ?
I see the MC you have is same as mine now. I hope it works with my 4 wheel disc brakes.? I have stock 76 Firebird calipers up front & Strange 4 piston race calipers in rear . Changing pedal ratio on 60 brake pedal wouldn't be easy with it's cast feature.. Just curious..I haven't got them bled yet !!!
#75
Is that article on the net somewhere? I would like to find out more about that car
#76
Jim |
#77
Hello Jim, I am here in Tucson also. Did you have the car soda blasted or walnut shelled or sand blasted??? I need to get my 62 Bonne wagon done and can't find anyone who will touch it. Thanks Andy
#78
Hey 61 I am not sure if you would be up for the drive but I have a guy in SoCal that will blast it for $1100 ( I will get the type I believe it is SODA), and he will do it for $1100 FLAT with trim on or off. I will get the info and post
#79
I was told several size MC's to go with??? 1&1/8 MC worked but had to push hard...just driving around driveway..I ran drum (8 Lugs)until the arrival of the 505 and increased speeds..especially in shorter 1/8 mile running mid 6's.....after a few trips almost to sand traps....bye-bye to drum brakes...I do miss my 8 lugs..!! I also destroyed a lot of 8 Lug drums...hot/hard spots..I think you will be fine with the 8 lugs..IMO..
I am hoping this 1" bore MC will work with the discs all around. Having a H of a time bleeding it by my self.. What color is it going to be....any ideas yet?
#80
Thanks, I am trying to stay local. I hope Jim has a lead.
