Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 08-26-2023, 03:32 PM
Chris Beck Chris Beck is offline
Default Stroker bottom end parts
Have a brand new set of ICON IC938-040 pistons with locks and Mahle moly coated rings King rod bearings0.020 under and 6.8" BBC style rods (used). All you need is a 4.25 stroke crank and a block that cleans up bore at 4.165. See pics, Ships from Langley WA. 98260 425-894-9290 C.B. $1150 + freight
ID:	618861   Click image for larger version
ID:	618863   Click image for larger version
ID:	618864   Click image for larger version
ID:	618865   Click image for larger version
Old 09-03-2023, 10:30 PM
grivera's Avatar
grivera grivera is offline
This is meant for a 400/461+ stroker?
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
Old 09-04-2023, 04:00 PM
Yes, that would be a good application, if you have a block that is not bored more than 0.040 over. You can get cast stroker (4.250) cranks with 3.000 mains for less than $500. I think the math works out to 466 C.I. and the pistons have a 10.60 cc relief to help with static compression. Hope this helps
