Old 11-19-2023, 12:39 PM
Tim Corcoran's Avatar
Default Doug Herbert Solid Roller Lifters
I have been running these for years with no problems and they are 100% made in the USA. Is anyone else running them? Anyone had any failures?
https://butlerperformance.com/i-2445...%3Fq%3Dlifters
https://www.herbertcams.com/tpv-h-po...-hippo-oiling/
Tim Corcoran
Old 11-19-2023, 04:27 PM
Dragncar Dragncar is offline
I had a single pair in my old 455 for over a decade beating the snot out of it.
I bought a set of used Comp lifters that one pair had a crack.
So I bought a pair from Butler. Even had a slightly different length pushrod in that hole that was .083 and the rest were .118" wall.
Engine never knew the difference.
Old 11-20-2023, 11:07 AM
Jay S's Avatar
Jay S Jay S is offline
I run them and have not had problems. I think they are currently made by Morel both and Howard’s and Bullet sell the same lifter with a different name on it. If you go back enough years I think I recall Crane may have made lifters for Herbert.
Old 11-20-2023, 02:39 PM
Ken MacNicol's Avatar
Ken MacNicol Ken MacNicol is offline
Ran a set for well over 2000 runs
Old 11-20-2023, 02:44 PM
mysticmissle's Avatar
that's awesome, durability. what kind of spring psi and lift?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 11-21-2023, 01:24 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
I have an old set I finally replaced , got them used from a member here. after i got a few years of service from them A few of the rollers started to feel rough, not sure if someone can rebuild these?
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 11-27-2023, 02:05 PM
Not sure on spring pressure , but cam is .630 lift
