Old 06-14-2002, 01:33 AM
trshman's Avatar
trshman trshman is offline
Hello one and all,
Around October of last year I had my front end rebuilt, soup to nuts, with PST components. Shortly after my 2nd alignment, around February, I noticed a metallic "snapping" sound coming from the front end.
It happens when the wheel's locked to the right and I'm pulling into a driveway with a lot of "rise" to it so that the right front wheel is significantly higher than the left.
Prior to the front end I had all suspension parts, front and rear, replaced with Hotchkis, except for the upper rear control arms. Nobody can find a reason for this or any marks on any components.
It doesn't occur that often but it bugs me, which I'm sure you'll all understand [img]smile.gif[/img] so any suggestions would be appreciated.
Thanks,
Bob G.
trshman's Avatar
Hello one and all,
Thanks,
Bob G.
Old 06-14-2002, 08:38 AM
My64GTO My64GTO is offline
RG,
Take a look at the stabilizer links, one may have loosened up a bit, or the rubber has been chewed up causing the stabilizer bar to snap up against the bolt/washer.
Originally posted by RG:
Hello one and all,
Thanks,
Bob G.
<font size="2" face="Verdana, Helvetica, sans-serif">
[ June 14, 2002, 08:39 AM: Message edited by: My64GTO ]
Old 06-14-2002, 09:52 AM
trshman's Avatar
My64GTO,
Thanks for the reply. Supposedly that was checked along with everything else and I was "told" there's no visible marks anywhere but I haven't checked it myself and that's really what I should do. Your post made me realize that.
Thanks,
Bob G.
Old 06-16-2002, 11:03 AM
you'll want to make sure everything is greased well also. you'd be suprised what noises dry suspension parts make. mike
former." --Albert Einstein
- Winston Churchill
