Old 10-21-2022, 09:45 AM
428 tempest 428 tempest is offline
Default wiper arms don't fit
66 gto with new wiper transmission and new wiper arms. Arms only go on halfway even with a little encouragement from rubber hammer. put on my 65 and they fit all the way down. tried my wipers on 66 no go. used caliper and both seem same ? any ideas?
Old 10-21-2022, 12:19 PM
428ho4spd's Avatar
428ho4spd 428ho4spd is offline
Sounds like an issue with the splines on the new transmission not mating with the arms.
Old 10-21-2022, 01:29 PM
But they both go half way on , i could see if they wouldn't even start? Splines look good also.
Old 10-21-2022, 10:34 PM
242177P's Avatar
242177P 242177P is offline
Caliper is good, but I expect you'll need many more measurements. I expect they use an interference fit (slight taper). If the splines were straight, the arms would slip right on and off, never getting tight. If the splines are deep enough, you could get away with just sanding down the outside diameter a little at a time? If the splines themselves aren't large enough (or deep enough?) work them with a file? A permanent marker might help show where the binding is at it's worst? Dunno. Thinking out loud.
Old 10-23-2022, 08:59 AM
400 4spd.'s Avatar
It's a manufacturing flaw with the transmission, and the vendors know it. I called The Parts Place to order one for a '67, and the sales guy told me I would probably end up returning it, so save the package! He said there was one company manufacturing them, and most had the same problem that you see.
He was right. I eventually bought an original from another member here and restored it.
Old 11-02-2022, 07:19 PM
Bought used transmission threw the new one away that came from the Parts Place . Why do they sell junk they know won't work???
Old 11-08-2022, 09:05 PM
GT182's Avatar
GT182 GT182 is offline
Yep, best to find a used one. I'm 99% positive someone on here has one. New is crap. Go to the 61-77 Parts Wanted section to ask for one......
https://forums.maxperformanceinc.com...play.php?f=448
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-08-2022, 09:19 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is online now
Same problem with a '66 Chevelle 2 years ago. Ended up rebuilding the original transmissions and the repop arms fit right on. Junk repop trans.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
